15
How can I delete multiple transactions in a batch in GnuCash?
My specific use-case is that I am treating each year as a standalone gnucash file. I start with a copy of the previous year and import the current year transactions into it in order to benefit from trained Bayesian automatic transaction mapping during import. After importing the current year data, I then wish to delete the previous year's data.
User
  • 393
As a workaround I made a shortcut key for deleting transactions. With GnuCash closed, I modified the accelerator-map file.
In GnuCash 2.6 and older: C:\Users\username\.gnu-cash\accelerator-map
In GnuCash 3.0 and newer: C:\Users\username\AppData\Roaming\GnuCash\accelerator-map
Ubuntu (as mentioned in comments): /home/username/.local/share/gnucash/accelerator-map
I changed the following line (you might need to add the line entirely)
; (gtk_accel_path "<Actions>/GncPluginPageRegisterActions/DeleteTransactionAction" "")
To:
"<Primary>Delete")
I removed the semi-colon ; (which acts as a comment character) at the beginning of the line and I added the text <Primary>Delete
The first time you use the key combination GnuCash will show a pop-up dialog box asking if you want to save the transaction and has check boxes to automatically do this in the future. Pick one of the check boxes. You can undo this choice in the future by going to the menu Actions->Reset Warnings... (a dialog box appears asking which warnings to reset)
Now I could delete transactions by pressing ctrl+delete (Note: this is the delete key, not the backspace key. But you can pick whichever key combination you want). Pressing and holding this key combination allowed continuous deleting at a predictable rate so it was quite easy to delete a few hundred transactions quickly.
(EDIT: Note in recent version, GnuCash 4.9, although rate of deletion might still be predictable it no longer seems to update the UI as you delete transactions when holding down the key combo, which makes it harder to eyeball the deletion rate. I am now more comfortable repeatedly pressing the key combo rather than holding down)
Might not be the best solution if you have many thousands of transactions that you want to delete but for a few hundred it was quite painless.
User
  • 393
As a follow-up to this very useful info, on a Windows PC, the file is located in:
C:\Users\UserName\AppData\Roaming\GnuCash\accelerator-map
The way the edited line is displayed in the above answer is correct but it may not be immediately obvious to everyone that like some other languages, the semicolon needs to be removed as well. The semicolon is a comment tag that disables the line it is on.
Notes:
<Primary> is the same as "Command" on macs and "Ctrl" on Windows. Other modifiers are <Shift> and <Alt> and they can be combined so to make it a bit more difficult to do accidentally, my new line is:
(gtk_accel_path "<Actions>/GncPluginPageRegisterActions/DeleteTransactionAction" "<Primary><Shift>Delete")
AKA: Control + Shift + Delete
I presume it was the same in earlier versions but I am new to GNUcash so it's also useful to note that, at least as of GNUcash 3.5, this keyboard shortcut triggers the Yes/No dialog to confirm that the transaction should be deleted. Additionally, you can select to ignore the dialog for the rest of the session or never show the dialog.
Tinker
  • 71
And here are my notes for a Windows (10) setting, when using the portable version of GnuCash from here:
GnuCash Portable website for download and docu
The file "accelerator-map" for the keyboard-shortcut-hack is now located here:
[path-to-your-portable-installation]\Data\GNCDataHome\accelerator-map"
I tested this on Win 10 pro 64bit and with GnuCash Version 4.13 portable just now and it works great. I used this syntax:
(gtk_accel_path "<Actions>/GncPluginPageRegisterActions/DeleteTransactionAction" "<Primary>Delete"); Martin
You can see that I took the information that ";" is for comments and I marked this line with my name, as the one I have edited for later reference. The file has got 292 lines, so could be useful next time I want to have a look.
TL/DR
I have noticed that GnuCash is getting messy, when I have to work on several "clients" in parallel: The settings (for example the active-period) are not properly kept separate for each project. I do accounting for several different NGOs and some cash-boxes.
This is why I am using the portable version. Even when working for the same client and starting a new calendar-year (as is the context of this question), I start a new install in a separate folder, and it is also a good moment to look for a version-update for GnuCash portable.
Martin Zaske
  • 181
I haven't tried yet but in theory you should be able to delete transactions with SQL using the SQLite file format. Of course you need to have a basic understanding of the data structures but then I imagine it to be quite powerful.
Ganesh Sittampalam
  • 30,396
  • 95
  • 119
Jan
