24
Many news outlets, such as this one (there are many examples), are reporting that the current US stock sell-off is due to a stronger-than-expected jobs report in January and fears of inflation and rising interest rates.
I don't follow the logic, so I'm hoping someone can explain to me:
  • How/why does increasing the number of jobs increase inflation?
  • Why would rising inflation (and interest rates cause people to sell off their stocks? Is it true that interest rates are intentionally raised to combat inflation?
  • What does this kind of news mean for me on a personal finance level? I personally don't actively invest in stocks at present, but do have some savings in the bank, but I'm sure other readers would be interested in a holistic answer covering stocks/bonds/cash/employment/etc.
Tom Au
  • 6,059
  • 22
  • 32
NeutronStar
  • 1,332
  • 20
8 Answers8
40
Many news outlets ... are reporting that the current US stock sell-off is due to a stronger-than-expected jobs report in January...
Had the market done well in the last few days those same people would have claimed it was due to the stronger than expected jobs report, and in fact oftentimes a strong jobs report does lead to a bump in the market. Furhtermore, inflation in the long run means prices increase, including stock prices; not the other way around. (Which is why a small amount of inflation is healthy for a generally growing economy.) It's true that interest rate increases temporarily stall the market, but they go up on purpose when the economy is doing well to give the fed more wiggle room to provide an economic boost in the future when necessary (by lowering rates). Eventually inflation has a larger effect on the economy than higher rates and the markets continue to rise regardless.
The current market dip is happening because it is happening. Perhaps some people (and trading algorithms) decided to temporarily lock in their recent gains, and others immediately followed suit, and then it snowballed into everyone falling in line. Sometime in the future (perhaps tomorrow, perhaps a month from now) some investors will get the bright idea to try to beat the slow growth of bonds with some large stock purchases, then others will try it too, and then everyone will fall in line again and up it goes. Rinse and repeat.
Patrick
  • 161
TTT
  • 47,380
  • 101
  • 152
17
First, I advise against attributing stock market movements to particular pieces of news. Many cable shows depend on your interest in this question, but unless the news is nuclear war, its long-term effect is generally exaggerated on the day that it takes place. And the jobs report really wasn't so out-of-line, and other similar reports over the last several years had no effect like this.
The rise in interest rates is in this case likely to result in stocks dropping for at least three reasons. One is that for some time the stock market (and to some extent real estate) has been the only place to get decent returns. Money might move into cash or new, higher-rate bonds. Not existing bonds; they have also been dropping in the expectation their real (inflation-adjusted) fixed interest rate will be less valuable. There is also the possibility that rising Fed rates coupled with the huge jump in the Federal deficit will make capital expansion much more expensive, hurting profitability. And finally there is the possibility that interest rates will rise enough to slow economic growth (take Trump's prediction of GDP growth north of 3% as nonsense) so much we go into recession, just as demand was finally picking up.
Andrew Lazarus
  • 1,811
  • 16
When the economy gets towards the theoretical Full Employment level (not the same as 0% unemployment), and employers still need more employees, then according to the law of supply and demand they should start to bid up wages so as to poach employees from other companies.
Practically, I find that dubious.
Why would rising inflation (and interest rates, I understand that interest rates are intentionally raised to combat inflation) cause people to sell off their stocks?
As @AndrewLazarus mentioned, the stock market has been the best place to get yields, since interest rates have been so low.
With rising interest rates, you can (theoretically) get good returns without as much risk. Thus, you sell off now while the market is high, so as to have cash available when things shake out.
I think it's the herd of sheep mentality, though, combined with algorithmic trading that kicks in when certain conditions are reached.
What does this mean for me on a personal finance level? I personally don't actively invest in stocks at present,
Not much. Maybe you'll get a bigger than normal raise.
If it's in an online bank, you'll have notice increasing rates over the past couple of months.
There are too many computer algorithms, and so many people automatically shoveling money into the stock market (401k, etc) for me to even dream of a holistic answer. Anyone who gives you one is guaranteed to be wrong.
RonJohn
  • 50,786
  • 107
  • 170
If the hiring market is strong, more people are employed and wages increase (as employers chase the better employees). It's not so much that more jobs causes inflation as that the same thing that causes more jobs causes wage increases. And wage increases lead to increased prices, otherwise known as inflation.
To combat inflation, the Federal Reserve reduces the amount of money in circulation. It does this by selling assets in its portfolio. This is mostly treasury bonds normally, but they expanded out to other securities. In particular, they own a lot of mortgage debt. Reducing the amount of money in circulation reduces inflationary pressures and it causes interest rates to rise. Because the Fed uses an interest rate target to tell when it has sold enough assets, this is often described as raising interest rates to combat inflation. But the actual effect is more direct than that.
If real (after inflation) interest rates are higher, then people who just barely preferred stocks at the lower interest rate now prefer the higher interest rate to stocks. And then of course there are all the people who now believe that stocks are going to fall, so they sell before the expected fall. Selling of course makes stock prices fall if not balanced by strong interest in purchasing.
Personal finance
This may be a good time to hit your boss up for a raise.
This may be a bad time to lock in interest rates that you will receive (e.g. a Certificate of Deposit).
This may be a good time to lock in interest rates that you will pay, e.g. for a mortgage or car loan.
Of course, all this assumes that this is the start of a market correction and not a one or two day event that will be followed by a strong increase over the next week or so.
Brythan
  • 20,986
  • 54
  • 67
I'm not a 100% on this, but from what I have read: Recent tax cuts created new jobs from new/ existing companies. However, the tax cuts means less money for the government. Which means the government has to borrow money. Therefore it is more profitable to invest in the treasury than stocks as it is safer. So people are selling their stocks to reinvest elsewhere.
Inflation is the result of an increased money supply in the economy. The economy has been growing faster over the last few months. This will impact the Fed's policy. They will drastically reduce the available money in the market (the supply), to avoid inflation rising faster than the actual growth of the economy, thereby effectively reducing the value of the USD as a legal tender. Reducing money supply will increase interests. Increased interest reduces profits of businesses (cost of capital increases).
Money supply is still high. The fed has been increasing the supply since the financial crisis and has only recently started to scale back. This additional money supply flowed to big businesses in the form of loans. Businesses were able to borrow a lot of money at low interest rates. This made profits soar (because very low costs of capital), which attracted investors into the stock market and as a result made the stock market soar to all time highs.
Unemployment is now low as well, and as a result of rising wages will impact the spending of consumers in the economy. This will also increase inflation, as prices of goods and services will increase due to increased demand.
But most of all, it seems the party of very low interest rates for businesses, and ballooning profits will soon be over (because of increasing costs of capital / interest rates). Investors in the stock market are taking their profits.
Arnold
The relationship between unemployment and inflation is known as the Phillips Curve
Think of it this way: Suppose you want your house painted. If there are many painters looking for work, you will need to pay less to paint your house than if painters are fully employed with other projects.
Think of a company as a stream of future earning. Each year a certain amount of money will be earned (or lost). What is the value of the sum of all the future earnings?
The value of each future payment must be discounted by 1/(1 + r)^t where r is the interest rate and t is time to find the present value.
For this reason, with no change in future earnings, the fact that interest rates are higher makes stocks (and all other streams of future payments) less valuable.
DavePhD
  • 488
Simple answers to your queries are following:
  1. How/why does increasing the number of jobs increase inflation?
Increase in jobs means more wages being paid out by companies. More wages lead to increase in spend. Increased spending leads to higher demand for products/services. Higher demand leads to increase in prices (low supply-high demand leads to price rise). Higher prices = Higher inflation.
  1. (part-one) Why would rising inflation?
I have just answered this question in previous paragraph.
  1. (part-two) what causes people to sell off their stocks?
I fear the answer to this question is rather indirect. More wages means more spend by companies. Higher spend on salaries COUPLED with potential increase in rates means decreasing margins in near future. Decrese in margins means a correction in stock prices.
  1. What does this mean for me on a personal finance level? I personally don't actively invest in stocks at present, but do have some savings in the bank, but I'm sure other readers would be interested in a holistic answer covering stocks/bonds/cash/employment/etc.
If you are saving in banks, then you are in a good position if rates are hiked. For others the simple advice is this: Never panic because everyone is selling. Not every company or asset is going to be affected by rate hikes. For example, a company employing high degree of automation and has savings may perform better in high inflation conditions. Hence the impact is on per-case basis.
Kannan
  • 556
