I always hear people telling me things like:
Diversifying your stock/investment portfolios helps ensure more profits/success.
It's common to diversify portfolios (usually this is said with no exact reasons given).
Diversifying your portfolio helps save you money
Above all, can anyone explain to me how:
1.Diversifying investments can help me profit more.
2.How it may or may not help more cut my losses.
3.How it's any better of a strategy than ... well ... not doing it.
I can't seem to fathom how just diversification alone will help me profit.
What's the gig with diversifying an investment portfolio, and why would I care for it vs. just investing and trying to profit in general? It's almost like it's preached, but without solid reasoning.
For example, if I just want to profit, why would risk tolerance matter? And how would diversifying anything help cut my losses/etc.? I'm genuinely interested in the logic here.
I am a short-term investor (i.e., I believe in making gains quickly; not holding anything too long).
Basically, diversifying narrows the spread of possible results, raising the center of the returns bell-curve by reducing the likelihood of extreme results at either the high or low end.
It's largely a matter of basic statistics. Bet double-or-nothing on a single coin flip, and those are the only possible results, and your odds of a disaster (losing most or all of the money) are 50%. Bet half of it on each of two coin flips, and your odds of losing are reduced to 25% at the cost of reducing your odds of winning to 25%, with 50% odds that you retain your money and can try the game again. Three coins divides the space further; the extremes are reduced to 12.5% each, with the middle being most likely.
If that was all there was, this would be a zero-sum game and pure gambling. But the stock market is actually positive-sum, since companies are delivering part of their profits to their stockholder owners. This moves the center of the bell curve up a bit from break-even, historically to about +8%. This is why index funds produce a profit with very little active decision; they treat the variation as mostly random (which seems to work statistically) and just try to capture average results of a (hopefully) slightly above-average bucket of stocks and/or bonds.
This approach is boring. It will never double your money overnight. On the other hand, it will never wipe you out overnight. If you have patience and are willing to let compound interest work for you, and trust that most market swings regress to the mean in the long run, it quietly builds your savings while not driving you crazy worrying about it. If all you are looking for is better return than the banks, and you have a reasonable amount of time before you need to pull the funds out, it's one of the more reliably predictable risk/reward trade-off points.
You may want to refine this by biasing the mix of what you're holding. The simplest adjustment is how much you keep in each of several major investment categories. Large cap stocks, small cap stocks, bonds, and real estate (in the form of REITs) each have different baseline risk/return curves, and move in different ways in response to news, so maintaining a selected ratio between these buckets and adding the resulting curves together is one simple way to make fairly predictable adjustments to the width (and centerline) of the total bell curve.
If you think you can do better than this, go for it. But index funds have been outperforming professionally managed funds (after the management fees are accounted for), and unless you are interested in spending a lot of time researching and playing with your money the odds of your doing much better aren't great unless you're willing to risk doing much worse.
For me, boring is good. I want my savings to work for me rather than the other way around, and I don't consider the market at all interesting as a game. Others will feel differently.
keshlam
  • 52,634
  • 87
  • 177
Diversifying is the first advice given to beginner in order to avoid big losses. For example in 2014 the company Theranos looked really appealing before it failed in 2016. So a beginner could have invested ALL his money and lost all of it. But if he had diversified he wouldn't have lost everything.
As an investor goes from being a beginner to being experienced, some still diversify and others concentrate. Mostly it depends how confident you are about an investment. If you have 20 years of experience, know everything about the company and you are sure there will be profit you can concentrate. If you are not 100% sure there will be a profit, it is better to diversify.
Diversifying can also be profitable when you lose money: because you will pay tax when you earn money, if you diversify you can choose to lose money in some stock (usually in December) and in this way cut your taxes.
Flux
  • 17,301
  • 74
  • 138
Dupond
  • 302
Any investor can make a bad bet, even Buffett. Even if you have done every bit of research on an investment possible you are exposed to random external events.. acts of god, and outright fraud.
fendermon
  • 212
Diversification is used by many to hopefully reduce the risk when bad investments are made. Diversification does not help you make more profits but instead averages down your profits.
There is no way one can tell whether a stock or portfolio of stocks will go up or down once they are purchased. In order to try to provide some protection against total loss of the portfolio, a lazy so called long term investor will use diversification as a way of risk management. But the best outcome for them will be an averaging down of their profits.
A better method is to let the market tell you when your purchased investment is a bad one and get out of that investment early and thus limiting your losses, whilst letting your good investments (as determined by the market) run and make larger profits.
Victor
  • 20,987
  • 48
  • 85
