16
Let's say I'm opening a new checking or savings account, assuming:
  • I already have another checking account
  • All accounts offer the same interest rates
Why would I ever choose to open a savings account?
I know that savings accounts are limited in terms of the number of transfers you can do, so that's one reason to prefer a checking account. But why would I prefer a savings account?
(Note: I'm just asking about the general case. Clearly, if one of them offers a $100 bonus and the other doesn't, then I would take the first one. Obviously, that completely misses the point of the question, so assume there are no special circumstances surrounding them.)
user541686
  • 3,385
  • 37
  • 47
7 Answers7
If your checking account has a card associated with it, then keeping funds in savings reduces the risk that some kind of fraud will wipe you out.
Bob
  • 69
Here are some typical differences between savings and checking accounts:
  1. The savings interest rate may be slightly higher. (Obviously not a factor in your case.)
  2. The savings may have limitations on the number of transactions that can occur per month. (This may be a positive or negative for you depending on your needs.)
  3. Savings may have lower fees, or easier requirements to avoid fees.
  4. Savings accounts may have a deposit-only option, whereas checking likely does not.
  5. Psychological effect of putting money in a "savings" account.
Depending on your banks offerings and your personal goals, you would have to decide which factors matter to you. It's certainly possible that you may conclude there is no difference in your case.
TTT
  • 47,380
  • 101
  • 152
If one has established a liquid emergency fund of 3 to 6 months income as suggested in several places here as well as being recommended by many financial planners then a savings account is a great place to keep that money.
All things being equal between the savings and checking account the limited transfers should be a non issue since ideally you won't be using that money and if you need to in an emergency you could move a whole months worth of expenses to checking in one transfer. The savings account gives you a place to keep the emergency fund segregated from your normal funds. Out of sight, out of mind as it were.
A savings account also gives you a place to stash funds intended for short term goals away from normal use funds. One such example I can use is that I am purchasing several plane tickets for various family members to come visit for Christmas. I have those funds set aside in a savings account so they don't interfere with my budgeting of my normal living expenses.
While these are just examples and your situation may vary they are both examples of where a savings account would be useful even if it is identical to a checking account.
Edit: using other types of accounts can also accomplish the same thing. Since we are using the assumption that the checking and savings accounts are identical the benefit of using a savings account is that it is usually inherently linked to the associated checking account without any additional effort on the part of the account holder. Any other account type would require additional effort, however minor, on the part of the account holder to link them in such a way that would make transfers between accounts as easy as possible.
homer150mw
  • 1,179
this is purely psychological. most people are absolutely terrible at keeping track of their finances. to the point where they will use multiple separate accounts for different types of spending or savings goals. when the average person tells the banker they want an account for the money they are saving, they get handed a "savings account" and don't bother to question how it is different from a checking account.
teldon james turner
  • 3,032
  • 14
  • 17
This is slightly broad and opinion based. If the interest rates are same and other aspects are same [or same to you ... for example savings account allows say 6 debits per month and you only need 4, then its same].
Unless one compares the specifics one can't decide. A checking account may have fees, at times waived if there is direct deposit set-up. It maybe more easy to get phone banking or other aspects.
Quite a few items were initially possible with only checking account, get a check book, get a debit card [not just ATM card], etc. These days there are multiple flavours of products that bank is lunching which blur out the lines, hence traditional comparison will not do justice.
Dheer
  • 57,348
  • 18
  • 89
  • 170
I think the issue here is you're starting with a criteria that doesn't actually exist in reality. A very small amount of research will uncover a plethora of options for savings accounts that pay far more interest than your basic checking account and don't require you to spend on the balance to earn the interest.
The point of saving is to have a pot of money that you can dip in to when you need it, or when you're ready to spend it for it's intended purpose. That pot of money is not supposed to experience a lot of transactions. It shouldn't be commingled with funds that come and go on a daily basis. It doesn't make sense to have checks or a debit card attached to your savings account, because you shouldn't need access to that money that way; not to mention that those two things open the door to fraud on the money that's supposed to be there for you when you need it.
Could you put your savings funds in to a checking account, sure. If we lived in a world where savings accounts that don't force you to jump through hoops to avoid fees didn't pay 10x more interest than interest bearing checking accounts that have similar ease of administration, more people may choose to house savings funds in checking accounts; but that's not the world we live in.
Thanks to the back and forth in the comments below I'm now more certain of my position that if you want a high yielding checking account you'll have pay fees or initiate a certain number of debit card transactions, or both. No one wants fees, and you shouldn't be spending on your savings in order to earn interest on the balance. It is very easy to juice your savings account to the best rates available.
quid
  • 49,074
  • 101
  • 161
It would be incredibly unusual for the same institution to offer checking and savings accounts with exactly the same features/benefits (including interest, etc). The reason is that (in the USA, anyways) the Fed makes banks keep a certain percentage of their total assets (called the reserve requirement) "in house." Checking account deposits cannot be re-loaned 100%--some of the money you put in your checking account must be held by the bank in its vaults. Savings accounts are not limited in this way.
So logic dictates that if depositing into one type of account is better for the bank than the other (ie, they can use more of the money to make money), they will reward people for using the one that is more beneficial to their bottom line.
I'm recalling this from college finance 101, so I may be slightly mis-remembering things, but I'm 99.99% sure that this is the primary reason you see checking accounts with lower interest rates--banks would prefer you to use savings accounts, and set up incentives so that you will.
Sorry, I know this doesn't really answer your question, but I think it may help you understand your options a little better (I hope!)
snuggles
  • 151
