19
I'm in the process of getting an apartment with my girlfriend and a friend. We plan on all sharing rent and utilities but there is a large gap in earnings between the three of us, mostly that I out-earn both combined. I want to do things as fairly as possible, so I'm unsure how to split the rent, and ensuing utilities.
Due to the area where I work, the apartment is more expensive than the others would be able to afford without me, and splitting things at the 33% mark would simply leave them next to no money outside of rent, or so I fear. How should I go about this?
Edit for requested information: All of our incomes are known between each other. Me and my girlfriend are sharing a single room.
Ranma344
  • 1,594
  • 25
8 Answers8
34
The simplest way to handle this is for you to rent the apartment and sublet to the girlfriend and friend. I'd split the utilities evenly, one-third from each. The reason for this is that each of you contribute evenly to generating the utility bills. It's not like your income makes the water cost more for you.
Utilities are driven by usage. Dividing them other than equally is likely to lead to more problems than it solves. Also, it seems unlikely that a different apartment would use significantly different water, electricity, or internet. Those are driven by the appliances rather than the size or location of the apartment. Only pay more for the utilities if you want something that they don't. For example, maybe you want HBO, etc. It would be reasonable for you to pay the entire premium if that's a luxury that they simply wouldn't buy.
I'd also divide the groceries evenly if you share and share alike. If you eat separate meals, you can buy separate groceries.
If the rent can't be split evenly but you could afford it alone, then you can just sign up for it. If you break up with the girlfriend and/or the friend moves out, you're still fine. You have your fancy apartment and can afford it.
The bigger problem comes if you can't afford the apartment without both the girlfriend and friend contributing. If so, you should probably avoid this situation. It's fragile. Any person leaving would put you in a financially untenable position. You can look for a new tenant to replace your friend, but you can't exactly rely on getting a new move-in girlfriend on demand.
Neither the girlfriend nor the friend can afford to be on the main lease. In case of emergency or tragedy, they couldn't replace you as a tenant. That's why they should sublet. Then their obligation is to you, not to the landlord.
How much apartment would the girlfriend and friend get if you weren't involved? What rents would they pay? That's probably how much rent they should pay for this apartment. You want a better apartment (or a better location)? That's on you.
You should only do this if you want to do it. If you want to share apartments with the girlfriend and friend, then do so. Work out something equitable. If you plan on moving in together to reduce your costs, then you don't sound like you are compatible. Obviously there are reasons to move in with the girlfriend aside from costs. Why can't the friend get his or her own place? The added rent probably won't do more than pay for the added room (you could get a one bedroom without the friend).
That points to an alternative way of calculating the friend's contribution: the difference between a two bedroom and a one bedroom apartment. That's the additional cost of the bigger apartment. If the friend can't afford that, then this might not be a good idea.
Summary
Make sure that you can afford the apartment if one or both of the friend and girlfriend move out. You can eventually replace the friend as the tenant but don't rely on doing the same with the girlfriend. Share utilities evenly. Possibly groceries too. The friend should pay at least the added cost of the additional bedroom. Don't expect either to pay more in the new apartment than they would pay without you. You should be the only one on the main lease; sublet to them.
Brythan
  • 20,986
  • 54
  • 67
This might get closed as an "opinion" question. Tough to say up front.
You are kind to be willing to do this, and if just you and GF, it would be simple, split the costs the same as the ratios of your incomes. Say you have twice her income. You pay 2/3 of bills and she pays 1/3. In effect, you are subsidizing her, but this is often the case for working married couples, one earning more than another.
But, this will mean subsidizing the friend as well. In theory, he has 1BR, and should pay 1/2 rent, 1/3 utilities and common food, etc. If he makes 1/2 your income, and so does GF, for simple math, he'll pay 1/4 of rent and utilities. That's an emotional issue, will you be ok with that? You'll be subsidizing a friend, instead of having a stranger pull their own weight.
JoeTaxpayer
  • 172,694
  • 34
  • 299
  • 561
I don't think there's a conclusive answer to your question, but I have a real world example for you.
I was in a similar situation for almost 6 years (I was the friend, but also the one with the highest pay). I rented a house, my name on everything. I made a separate contract with both my friend and his GF and they both rented a room from me.
I looked up the total m2 of the house and divided the rent by that number. Multiplied by room sizes I knew what everyone had to pay for their personal space, I simply divided the rest by 3 to find the remainder of everyone's rent.
I don't know the numbers anymore, but here's an example:
house = 150 m2
room 1 = 10 m2
room 2 = 15 m2
room 3 = 25 m2
shared space = 100 m2
rent = 800,-
This gives 5.33 per m2
The shared space is worth 533.33 Divided by 3 is 177.77, So the total rent for each room is:
room 1 = 10*5.33 + 177.77 ≈ 231
room 2 = 15*5.33 + 177.77 ≈ 258
room 3 = 25*5.33 + 177.77 ≈ 311
We divided the rest of the costs (gas, power, water, etc...) evenly. This was fair in our case, because the rent was directly tied to the size of the rooms. The only thing we had left to do was give the poorest person the smallest room.
Kevin
  • 348
Realistically, fair is whatever you all mutually agree upon. Some people can do means based splits, some people can't.
My recommendation is to split things evenly, based on actual used space or usage. Do you have a 2BR with similarly sized rooms? Break it up by room, so in this case your GF and you pay 50% and the other person pays 50%.
Maybe there's a garage or one BR is bigger. I've seen splits not 50-50 based on these factors. You may consider paying a third all around for rent but I would try to avoid solutions that are not usage based.
If you don't and try for a "means" based split, best case scenario is nothing really is different.
But the worst case scenario is setting yourself up to be taken advantage of - because you are effectively subsidizing other people, this often changes relationships. Not always, but often.
Frankly, the best option here is to find a place that is more affordable for everyone. Trying to make it so that your GF and roommate are not going to be in a difficult financial place by living with you, it resolves all the problems here.
enderland
  • 4,186
  • 45
Another option is to look at the rent difference between where you need to be and where the others would rent, without considering your job. You pay the difference, which is due to your unique requirements, and split the remainder equally.
Myself and my partner do things a little differently to most. We split accommodation and utilities payments by net income proportion to ensure that we both have the same amount of spending money.
For example;
  • if we both earn $40,000pa we both pay 50% of the bills
  • if she earns $50,000pa and I earn $25,000 she pays ~66% of the bill
The really important bit is net income. We take off a whole bunch of payments, e.g;
  • Pension contributions
  • Student loan
  • Employer subsidised healthcare
Our contributions go into a joint account and the rest is our money to spend. The upshot is that we both get to enjoy the same minimum quality of life because we both get the same amount to spend at the bar.
Gusdor
  • 113
If you or they feel uneasy about you simply paying more rent than them for equal usage, you can work out an agreement where they "pay" in other ways. For example, I once lived with someone that made about double what I did, and so he paid more rent than I did. In exchange, I was responsible for cleaning the kitchen. If your roommates hate cleaning then you could substitute something like running errands, cooking, or looking after plants/landscaping. If they have some specialized skills then they might be able to provide those instead (car maintenance, financial management, etc.).
Of course you'll want to agree ahead of time on what the conditions of satisfaction for the task are, such as how often the kitchen will have to be cleaned and what the definition of "clean" is. You also can't be a jerk and make their job extra hard, such as by completely trashing the kitchen every night.
Obviously it will depend on the temperament of your roommates whether or not they'll be happy with this or feel insulted being "the help". It worked for us because it was a task he hated and one I didn't mind, and it kept me from feeling like I was mooching off him. I would feel them out when you propose a possible rent and utilities split. If they feel like it's an unfair burden on you, but they can't afford more, then you could suggest this as a way for everyone to contribute equally.
Whatever you decide to do, don't hold it over their heads that you pay more. Agree on something that everyone feels is fair, whatever that is. If you want a concession due to paying more (such as you get the garage, get to pick the art on the walls, whatever), then agree to that up front. Then accept that you've made a fair deal and they don't owe you anything beyond what you've all agreed to. It's awful to feel like you live in someone else's home and that you are getting into ever deeper debt with a close friend or significant other, and it will breed resentment. If you can't do that, then don't share an apartment with them at all.
Summary
The most important thing is that everyone feels it's fair, regardless of the numbers. If you cannot get to that agreement through dollars alone, you can have them contribute to the home in other ways, such as cleaning, cooking, or performing maintenance. Just make sure that everyone truly does feel it's fair and that you are all equals.
Kat
  • 1,193
  • 15
-2
Does your apartment have several bedrooms that are all different in size? If yes, then everyone can pay by square footage. However, if you share the room with your girlfriend, it won’t work. Even if your live in a master bedroom with her, you friend will probably pay more than your girlfriend.
I heard there are websites that let each roommate bid the max they’re willing to pay for each room in the apartment. You can try one of these service.
Or you can simply divide the rent between three of you, but utilities will be covered only by you.
