Lottery withholding taxes are quite substantial, and from my understanding of the federal tax regulations, gambling winnings can be offset by gambling losses up to the amount won.
So if someone won 5 million dollars from a lottery ticket, and had a lot of it automatically withheld, that same withheld amount could be used (for fun, bankroll, consumption) by further gambling at high roller tables and slot machines and other lotteries, and losing.
This would then incur a tax deduction and if more was withheld than you won from the lottery ticket, then you would likely get it back from the government. In practice this would have to require spending the post tax cash, and getting a large refund, which is still a lot better than not having access to that portion of the original lottery proceedings at all.
Am I understanding this correctly?
Alex B
  • 17,394
  • 58
  • 108
CQM
  • 20,209
  • 54
  • 93
You are falling for the common misconception that 'high' taxes means 100% taxes. Which is of course wrong.
Take a simple example (all numbers are millions!): You win 10 in the lottery, and they keep 50% of it - which is 5 - for taxes. You whine, and blow 2 of the remaining 5 in Vegas.
Now you have 3 left (instead of 5), and at the end of the year - assuming you have proof that you blew 2 - you get 50% of the 2 back, which is 1.
Now you have 4 instead of 5, and you had to wait a year for getting the fourth.
why would 4 be better than 5? you basically blew 1 to have the fun of blowing 2. In other words, blow 1, blow 1 free...
And in reality, taxes are not 50%, but lower, so your math looks worse.
Generally, remember, taxed money is still money. That counts for blown money as well as for made money.
Aganju
  • 38,107
  • 59
  • 121
I think it's obvious that it would never make financial sense to throw money away just to get a percentage of it back in the form of a tax refund. However, in this particular situation there may an interesting wrinkle worth exploring.
Suppose you went to a casino and considered playing a game where the house has a slight edge of about 1% (blackjack, etc). Mathematically you should never place a bet. But now suppose the casino modified the game such that every time you lost you were given 25% of your original bet back.
  1. Does getting a rebate on your losses now make the game in your favor?
  2. If yes, wouldn't it then make sense to always go gambling with your lottery winnings since you are getting a guaranteed rebate if you lose?
It may seem strange but the answers are 1 = yes, 2 = no. Here's why:
  1. Without the rebate, the expected value (EV) on a $1 bet is $-0.01. So for every $1 bet you make, you can expect a return of about 99 cents. With the 25% rebate on losses, your EV becomes +$0.12 meaning you can expect a return of $1.12 on each $1 bet. This would be a good bet to continue making all day long.
  2. The flaw in the logic in question 2 is that you also have to pay tax on your winnings, meaning any tax rebate you receive is offset by the same amount when you win. This brings you back to the original 1% disadvantage that you started with.
So what can we conclude? Under normal circumstances when you don't have any gambling winnings to offset against, gambling at a casino is a much worse bet than it seems. Since you have to pay taxes on your winnings, but cannot deduct your losses, even if the house edge is only 1%, your true EV (with a 25% tax rate) ends up being around 13 cents on the dollar, so for every $1 you bet your return is only $0.87. If you already have winnings in the same tax year, then your expected return on a $1 bet jumps back up to the $0.99 that the casino advertises, but in either scenario, it's always a bad bet.
TTT
  • 47,380
  • 101
  • 152
Kindof.
A couple of things:
  1. The assumption here is that you cash out at the end, which is obviously not going to work when you're casino-hopping. But when the winnings are substantial enough the risk of people "forgetting" to put them on their tax return is substantial enough to warrant withholding at source.
  2. You need to substantiate the losses, which is not always easy. You need to show receipts and/or other proof of the money spent and how exactly it was spent. From my personal experience dealers don't give receipts when you buy tokens at the table, but I guess when you're dealing with thousands of dollars at a time things change.
littleadv
  • 190,863
  • 15
  • 314
  • 526
