If I place a stop loss GTC order on my shares at $80, and it reaches that price during pre-market or after hours, will my order get executed?
I ask because a lot of the time the stock opens at a different price than what it closed at, so if the stock sank from $85 to $50 during after hours, I'm wondering if my GTC order would get executed.
Franck Dernoncourt
  • 11,883
  • 13
  • 60
  • 147
bigpotato
  • 751
  • 15
You'd have to check the rules for your broker to make sure that the term is being used in its usual sense, but the typical answer to your question is "no." A GTC will execute during market hours. You would need to explicitly specify extended hours if you want to execute outside of market hours (which your broker may or may not support).
When I place an order with Scottrade I also have to specify if I am wanting to trade outside of normal hours.
Jack Swayze Sr
  • 2,446
You typically need to specify that you want the GTC order to be working during the Extended hours session. I trade on TD Ameritrade's Thinkorswim platform, and you can select DAY, GTC, EXT or GTC_EXT. So in your case, you would select GTC_EXT.
