-1
Several people have recommended that I not earn a Master in Business Administration (MBA) because it "is overrated". Why do people say this? Is it true? Can you please explain to me?
If your answer is yes, can you suggest another masters degree option?
dg99
  • 6,056
  • 27
  • 33
nelruk
  • 123
For some situations, an MBA can be overrated in the sense that given the cost of time and money, it isn't going to be a great return in some cases. There can be tens of thousands of dollars and a couple of years to get an MBA that some people believes should automatically make them worth $x more in their salary and life should be simple.
I'd likely inquire as to what expectations do you have for what an MBA will do for you. Are you expecting to make connections in getting the degree? Are you expecting to learn about how to run a business from the coursework? Are you expecting something else? Depending on what you are expecting, I could see MBA as being anything from a great choice to a lousy choice for people.
As noted by Pete Belford's comment, an MBA from a "degree mill" would be all but worthless. Where you go can reflect the value of the education as some universities are known for their program about this such as Ivy League schools.
JB King
  • 10,166
  • 29
The quality of the MBA is really what decides if it's worth it. You have to make sure the school where you are going to is highly regarded or even prestigious. There is a big difference between what you find prestigious and others find prestigious. The student believing it is an awesome school is not enough, the companies and recruiters must believe it too.
Make sure you do your homework on the ranking of the MBA program. Additionally, your undergraduate plays a role how well your MBA is perceived. A decent undergraduate degree complemented with an MBA from a highly ranked school will put you in a trajectory for a high salary and a management position.
ConfusedDeer
  • 2,750
  • 13
  • 16
It depends on what you want it for
If it is just salary then maybe not, for instance, some MBA programs may suggest their graduates make $100,000 per year, but you work in an oil field barely finishing high school and make $300,000 a year.
If you go for the MBA right now, you may miss your chance to work in the oil industry for another few years (or weeks), but at the same time, the MBA lasts forever (although, real world experience is also relevant) and it may give you a leg up when you are 50 years old in the unemployment line (or maybe not, because you are overqualified)
everything in life is a cost/benefit analysis
Passing the GRE lasts for five years, so keep that in mind
CQM
  • 20,209
  • 54
  • 93
