10
I'm renting an apartment from an individual. The landlord and I discussed the possibility of paying rent electronically. My bank (BofA) has some kind of electronic payment option where I'd enter the payee's account number and use that instead of mailing the checks.
Are there any downsides to paying rent this way? Is that different, legally, from "wire transfers"? What if the payee (or the payer) makes a mistake in the account number, or the payee's account runs into problems?
Gagravarr
  • 802
MWB
  • 551
  • 19
With BofA, you can just enter their address and it will mail them a check instead of needing to wire it to them. You don't need your landlords permission to do this (just let him know to expect the check in the mail). I did this for years, and other than the fact that the arrival date may vary by a day or two (presumably due to mail or processing delays), had no issues with it. It is a great way to make sure your rent is paid on time (if you've got till the 5th, just set it up for the 1st and you should be fine).
The same is true of most other banks who have online bill payment, with the main difference being the time variability of delivery. I've not come across any that charge for this. It even saves you the cost of a stamp, envelope, and check.
Update: There are also some marginal difference between banks about how records are kept and when the amount is deducted from your account. The records keeping probably works to your advantage if they ever claim you missed a payment (you have record it was sent, even if they never cash it). The variation in deduction from your account (i.e. when it is sent vs when it is cashed) could play out different ways and isn't anything that big to worry about.
Jared
  • 1,727
  • 14
To answer:
Direct payment (via online banking) is pretty common in my country (UK). There is a real chance that if you make a mistake the money will not be recoverable, since the bank only undertakes to do what you tell them to do, not what you intended to do.
While not necessarily legally binding, the usual procedure to make sure the payer doesn't make a mistake over account numbers is either to copy-paste them into online banking, or to visually compare them several times side by side and call a friend in to make sure they think they match too.
You want to get something signed by your landlord, or emailed to you by them, with what they say their account number is. So if they do make an error you have proof it's their mistake, and that you paid to the account they requested you to. They can play the same check-it-thrice game their end before sending you the details.
If you want to be really sure, first make a payment of $1. Confirm that it ends up in the right place, then you can safely use the same details again for future payments. Assuming your bank remembers them for you, there's no further danger of mistyping the numbers.
Steve Jessop
  • 1,583
  • 13
No. Where I live there can be upsides. Some banks charge for paper transactions involving checks (cheques).
Yes, wire transfers are effectively anonymous and can be picked up as cash without a bank account, which is why they are popular with crooks. Electronic payments go into a known bank account and are traceable. The bank should be able to provide proof of payment in any dispute.
Note: the use of these terms vary from country to country. "Wire transfer" may mean something different in your locale.
You'd have to ask your bank if the erroneous payment can be withdrawn.
My bank's online banking service allows you to set up account details for people you expect to make future payments to. This reduces the chances of making a mistake as you pick the recipient from a short list rather than typing in a number.
If the payer's account has insufficient funds, either the bank will refuse payment or your account will be overdrawn (and you will be charged heavily for if no overdraft facility has been arranged in advance). I think this depends on the bank. I've seen both situations.
I don't know what happens if the payee's account is locked or somehow unable to accept the payment. I'd be astonished if the money disappeared from my account, didn't arrive in the payee's account and the bank could give no satisfactory explanation. I'd expect the money to remain in the payer's account.
Example Western Union money transfer option
See also "Wire transfer scams" "Crooks like their victims to use wire transfers because the money moves fast and they can take the money and run before the victim discovers the truth,"
So yes "wire transfers" are different from bank-account to bank-account online transfers.
RedGrittyBrick
  • 4,243
  • 13
  • 26
