Can wire transfers be reversed? Is this codified into United States or International regulation/law anywhere?
Unless there was a mistake that you can blame on the bank (e.g.: they copied the numbers wrong from the form you filled), wires generally cannot be reversed.
- 190,863
- 15
- 314
- 526
If the error is because of you, you can request the Bank to see if there is a possibility of recall. However this is normally available only to large corporates. There is a window by the time you submit an instruction to the bank and the time it is fulfilled and recall is technically feasible. Once the Bank has processed the instruction, reversals / recall's are not possible by Law as Bank does not know the underlying reason for making the payment.
If its a Bank's error then the obligation is with the Bank to credit back the funds to you irrespective of whether Bank is able to recover the funds from Beneficiary.
- 57,348
- 18
- 89
- 170
