In this Investopedia explainer about TIPS, it says:
The yields on TIPS are often negative. This is because after taking into account the effects of inflation, the real yield is negative. For instance, if standard two-year Treasuries yield 1% but inflation is 2%, then the real yield is -1%.
This makes no sense to me, since I thought that the principal in a TIPS is inflation-adjusted. So if the principal is P, then in the above example the yield after 1 year would be P * 1.02 * 0.01, i.e. 1% in real terms, not negative in real terms.
Am I missing something?
The arithmetic
Writing out TIPS's math, as I've understood it, shows how TIPS' real returns are exactly the stated interest amount. If I've misunderstood how TIPS actually work below, please point out the lines that are wrong.
Let's say that I buy a 1-year TIPS bond from the Fed on Jan 1, and hold it to maturity. For simplicity, it pays coupons annually (in real life they're paid out twice a year).
  • X is the original purchase price.
  • y0 is the purchase year.
  • y1 is the maturity year. y1 := y0 + 1.
  • A is the inflation during y0.
  • B is the interest.
Let A and B be defined as (1 + percentage/100). For example, if inflation is 2%, A is 1.02.
After a year, the original principal X becomes XA, and the coupon payed out in y1 is XAB. The returned principal at maturity is XA. So the total return is:
Cash at maturity / cash at purchase
= (XAB + XA) / X
= AB+A
= A(B+1)
This is the total return in y1 dollars. To get the real return, i.e. the return in y0 dollars, divide by inflation A:
real return = A(B+1) / A = B+1
This real return of B+1 is by definition positive. Which step(s) above were wrong?
It's because the reported "yield" does not take principal increase into effect. The interest rate is fixed but the principal is adjusted with CPI changes.
So if you buy a bond for $1,000, it pays a 1% coupon, and the princiapl goes up 2% to 1,02. Your total return is higher than 1% but the "yield" of the bond is still based on the 1,020 purchase price and the 1% coupon. The real yield of the bond is then adjusted for inflation, which makes it negative.
Note that future principal increases can't be known ahead of time, so the forward-looking yield can only take the coupons into account, not the principal increases.
D Stanley
  • 145,656
  • 20
  • 333
  • 404
