34
My credit card company detected fraud on my account. They contacted me about this fraud, we identified fraudulent charges.
I was also told my current cards on the account would not work and I would be sent new cards.
The new cards I received have the EXACT same information as my old card:
  • number
  • CVV
  • expiration date
  • name
How does issuing a new card, with the same information prevent further fraudulent activity?
The only thing I could think of was that the fraud originated with a skimmer or a compromised vendor system. However the fraud detected were card-not-present transactions from online vendors. A skimmer also has to read the same information about the card to have any value to a thief for cloning or card-not-present transactions.
Freiheit
  • 8,772
  • 44
  • 65
5 Answers5
49
Tl;dr Block your card NOW, the new card is compromised.
Call the credit card company's 24/7 line and report the card compromised. Do that before reading on, to avoid fraudulent changes to the card.
Two things might have happened:
Scammer
It's not in fact the credit card company that contacted you prior, but scammers. If this is the case you need to report it to the credit card company asap, to avoid fraudulent charges. When they contacted you, did you reply to the info they had, or did you investigate and contact them using information you found elsewhere? If you investigated and used the info you found elsewhere it's probably not scammers that contacted you, if not this is a possible scenario.
Technical problem
The second option is that its' a technical problem that you got the exact same information. But if this is the case the persons that previously tried to do fraudulent charges still have access to your "new" card details, and you should regard this as a compromised card. Block it asap.
This happened to me once, I got 2 cards with identical information. My deduction was that the CVV will be the same if all other info is the same. I called the bank and they issued a new card, which had new info. But my case was different, since there were no fraudulent behaviour I didn't really worry.
When the cards are blocked
The most important thing is to get the cards blocked, no matter the cause of the problem. And use information found elsewhere to do that. When that's done you can relax. Now you can think about what to do next. I would ask for a new card, with all new information. And record the call, if you're allowed to do that according to applicable laws where you are.
In the future please be a bit careful of where you use your card, especially online. It's very easy for a dodgy company to save the card details and use for fraudulent purposes.
Polygorial
  • 1,061
You are right, something went wrong in the process.
You should contact them and ask for a new card with a new number, as the old one is compromised.
Aganju
  • 38,107
  • 59
  • 121
If it's legit, you're in the 1 in a 1000 cases where the CVV, which is supposed to be random, pulled out the same number.
But the law of probabilities would tend to say it's a scam or an error. In all cases, call your bank and get an answer and a new card (since having 2 cards with the same number defeat the security of the system, they are supposed to be unique).
xryl669
  • 321
As much as I agree with most, if not all of the other answers, this is really a question you should be asking your credit card company, not us. They can take the proper steps (which it seems they did not do already).
I agree that this is a bizarre situation; and personally I have always received an entirely new card after any fraud event. I see no way that an identical card stops fraud. (The only possible case I can think of is when a chip reader is involved, we have no way of knowing if the chip is different. But that still doesn't help with manual transactions.)
David
  • 41
You don't need to panic that's for sure. It's not your money that is liable with a credit card. If it were your debit card they are stealing money from you. With a credit card it is the banks 'money' that is liable. This means you don't have to pay for any items or services purchased on the credit card by the fraudster.
Inform the credit reference agencies however because it can take up to 60 days to amend a credit record. There are services available which get attached to your credit file that instigate a 'futher checks' option whenever trying to get a new line of credit with a broker or direct lender such as your bank.
The agent who has dealt with your call has definitely re-ordered a card as a 'lost'and selected the incorrect option when processing your data. This is a human error which entitles you to make a claim for redress (not compensation) from your bank. Typically these cases settle for a small 3 figure sum in the low hundreds, however if your credit file has been damaged by this you can pursue a higher level claim. They are heavily regulated on data protection and management and have entire teams dedicated to investigating internal agent errors.
Note that getting your card replaced does not stop a fraudster still using your data. When a bank cancels the card they just disable its RFI chip and shut its mandate numbers down. If the fraudster already has your information, ordering a card doesn't make it magically dissapear out of their hands. They can and do still spend money just with your information on a copied card. You then have to ring the bank again and it keeps going on until either they (without telling you), or you, cancel it completely and reapply for a fresh account.
What I would do is call the bank and cancel the card. I wouldn't reorder one on the phone I would book an in-branch appointment and speak to a person's face. Get written proof that you have attended the bank for the set reasons and get the bank to sign it.
Contact the credit reference agencies via email (for your records) and provide them with a copy of the confirmation that fraud has been committed in your account and let them deal with it from their end. That way you've covered all your angles if anyone wants to knock on your door asking for payments on a yacht somewhere in the Pacific.
Report it to the Police if you feel its necessary but be advised it can take from 12 months minimum - unlimited amount of time (in their own words). Most cases rarely get solved due to the mass volume they have to process. I believe they are about 3 years behind to-date.
Barb
  • 77
