I've been building my emergency fund through automatic deposits into a Roth IRA at TDAmeritrade. This has been working well, since the money is out of sight, out of mind, and I can easily withdraw it as needed.
But, I don't know what to do with the money in there. The interest on cash is terrible - .01%. What about Bonds, Bond Funds, Bond ETFs, T-Bill ETFs? Are these low-risk investments? Do they ever lose a significant amount of value? I'm ok with a small amount of risk.
Or, should I just dump the money in a high-yield savings account?
Cloudy
  • 9,551
  • 34
  • 52
MattMcA
  • 837
5 Answers5
20
Wow. It's clear I'm outnumbered.
When I'm approached with the question (and keep in mind, it's usually a couple data points and little else) "I am getting started, with no other money do I fund a retirement or emergency account?" I often suggest they put the funds into a Roth, in a money market fund, and treat it like an emergency account. If there's in fact an emergency, there's no penalty to withdraw the deposit and we're talking peanuts for interest today.
With no emergency, two things could happen:
A) As the account grows beyond what's needed for emergencies, the excess can be invested long term. B) As the investor earns more money and saves up enough to have a true emergency account separate from the IRA, the Roth can be fully invested long term.
The 'Bad idea' stems from the view that one is using their Roth as an emergency account, which of course is bad. The subtle difference is one has no retirement savings and puts their Emergency account into the otherwise unused Roth. As time passes, they've protected more funds to grow tax free.
In the end, the most important thing is whether the person is saving and not tapping for simple non-emergency things. I'd rather see a guy with $25K in his Roth and no other funds than to have $5000 in his bank account because every time it gets larger he feels compelled to spend it.
My answer to Matt is to treat it for now as you intended, low risk, CD or cash (money market).
JoeTaxpayer
  • 172,694
  • 34
  • 299
  • 561
12
Why are you saving your emergency fund in a Roth-IRA? That type of fund should be for retirement. I know you can pull out your principal but that would mean in a crisis you will be destroying your retirement fund.
Remember there is an annual limit, it could take years to replenish it if you have to pay for a big repair, or period of unemployment.
The emergency fund should be kept in a very safe account. I would just keep in a high yeild account at a Credit Union
mhoran_psprep
  • 148,961
  • 16
  • 203
  • 418
The Roth vs not debate is irrelevant to the question. It doesn't matter where your emergency fund is kept, as long as it is liquid and safe.
I said it before in an answer to another question:
your emergency fund is not an investment -- it's your safety net
This answer also says it well:
an "emergency fund" is just that... for emergencies... NOT investment.
While it "hurts" not to have your emergency money making more money... its MORE IMPORTANT to have quick access to it.
So at TD Ameritrade, just park it in their FDIC deposit account. It will not earn any meaningful interest (at least until rates rise), but you'll be able to have access to it when you need it.
Note that I would caution against putting it in a money market mutual fund. They're safer than many other investments, but they're not FDIC insured against loss and there is a potential for temporary loss of liquidity.
In late 2008 when the credit markets collapsed, a lot of people suddenly became unemployed -- and needed access to their emergency funds. When Lehman Brothers went bust in September, the Reserve Primary Fund (with billions of dollars in their fund) "broke the buck" -- they lowered the price of shares below $1, meaning investors lost principal. The worst part is that investors were not as liquid as they wanted to be: the fund froze and it was hard to get money out.
The lesson to take away from this is that one of the times you're likely to need access to your emergency fund is during a macroeconomic crisis. This is also the time when any investment that isn't guaranteed safe may potentially be (at least temporarily) unavailable or decline in value. Emergency funds should be 100% government insured.
When you have your Roth funded to the point where there's extra money beyond the emergency fund, you can start investing in higher-yielding vehicles: stock or bond index ETFs would be a good start. But then that part of your Roth starts to look like a retirement account and not an emergency fund.
If it were me, I'd open a Roth at a stable local bank and just keep it in their FDIC insured money market deposit account. Then if I wanted a slight boost, I might put the "upper half" of my emergency fund into short term CDs, but even CDs aren't worth much at the moment.
bstpierre
  • 10,034
  • 33
  • 65
You could put in in a Money Market Fund. These are designed to always be $1 per share, and not lose money. Of course, it still, very rarely, happens and is called "breaking the buck" when they do.
Sounds like the high yield savings is the way to go. The rates will be the same as what you can get from a Money Market Fund, but you also have the added advantage that the account is FDIC insured.
BTW, using a Roth as an emergency fund is a terrible idea. It is true that, since you already paid taxes on your contributions, you can withdraw those contributions without incurring penalties. However, you have to file paperwork to do it, and since it's not common, the IRA custodian is likely to screw it up. Plus, you have to keep track of what were contributions, and what was investment returns, to not run afoul of the penalties. And it will take time to do it, which you may not have in an emergency.
Considering you're only looking at getting 1% interest anyway, there's no reason to use a Roth account as an emergency fund. You can set those same automatic deposits into a savings account.
Patches
  • 3,501
  • 17
  • 25
A Roth IRA is intended for retirement. Before age 59.5 (I think), you can only withdraw the amount you deposited without penalty. It's great you're saving in a Roth, but you shouldn't put savings in there that you will need before you reach sufficient age. And since it's long-term, you can invest in things you expect to grow over the long term, like equities.
You should keep emergency funds either in federally insured, extremely liquid accounts (bank savings) or money market funds (which aren't insured, but are close enough to zero-risk). Yes, the interest rates are terrible right now. But anything else would potentially leave you with insufficient funds in the event of, you know, an emergency.
Rick Goldstein
  • 3,436
  • 17
  • 19
