23
This past summer, I worked a normal summer job and received a W2 form. However, I have also been tutoring two fellow students at the university I attend. They have been paying me "informally", eg they simply gave me dollar bills at the end of our tutoring sessions. I've made a total of $458 this way.
My question is: how do I indicate this income when I'm filing my taxes? Form 1040 item 1 is "Wages, salaries, tips, etc. Attach forms W2", which seems inappropriate because I don't have a W2 for this income. The guidebook says:
IF YOU... have additional income, such as business or farm income or loss, unemployment compensation, prize or award money, or gambling winnings.
THEN USE... Schedule 1, Part 1.
Schedule 1, Part 1 has a few items that (to my naive eye) look like they could fit the bill:
Item 1: Taxable refunds, credits, or offsets of state and local income taxes.
Item 3: Business income or (loss). Attach Schedule C.
Item 4: Other gains or (losses). Attach Form 4797.
Item 8: Other income. List type and amount.
Item 8 seems the most promising to me, but for all I know none of these are correct. Where should I indicate the "informal" income from my tutoring sessions? Do I even need to report it?
MegaWidget
  • 333
Let’s start with your last question first:
Yes, you are supposed to report it, as this is considered income. It was not simply a gift, because you did do some work in exchange for the money. Having said that, I will point out that, because it was all in cash, it is unlikely that the IRS would ever find out about it if you did not report it.
Where should I indicate the “informal” income from my tutoring sessions?
You found both of the places where it could go:
  • Schedule 1, Line 3: Business income
  • Schedule 1, Line 8: Other income
Let’s look at the two options.
As business income, you have to fill out a Schedule C (or Schedule C-EZ) for your business. The advantage here is that you get to deduct business expenses. Did you drive to your tutoring sessions? If so, you can deduct an amount for mileage (58 cents per mile in 2019). Did you purchase any books or materials that you used while tutoring? If so, those are deductible.
A disadvantage to a business is that you have to pay self-employment (SE) tax. However, there is no SE tax on income amounts below $400, so if you can deduct $58 worth of expenses, there will be no SE tax.
The other option is to consider your efforts a hobby and not a business. This is the easy option: No Schedule C, no business expense deductions, no SE tax. You just put $458 on Schedule 1, Line 8, and call it good. You’ll end up paying your regular tax rate on that amount.
In some cases, the IRS will insist that you have a business and require a Schedule C. In other cases, the IRS will deem that you do not have a business and will disallow your business expense deductions. The IRS has listed nine criteria that they use to determine what is a business and what is not. At this level of income, it probably doesn’t matter. But if you plan on continuing or expanding your tutoring, it should probably be considered a business.
Ben Miller
  • 116,785
  • 31
  • 330
  • 429
It is not a smorgasboard. Your facts and circumstances decide which you must do. Based on yours:
Pretend you got a 1099-MISC for that income. File Schedule C.
And you report it exactly the same as if you had gotten a 1099-MISC. This means you must go through the rigmarole of filing Schedule C, which will seem weird because you don't have a sole proprietorship. Actually, you do. You become a "sole proprietorship" (or "partnership") by default, anytime you do business without a more formal structure like an LLC or corporation.
Documentation of this area used to be quite poor, but the emerging gig economy has led IRS to create a site just for that.
Also file Schedule SE.
I tried to classify this as line 1 employee income; can't do it. The barrier is SS/Medicare/SE tax. For the same reason, reporting this on Schedule 1 Line 8 is flat wrong for you. By using Schedule C, the number drops right into the easy short-form Schedule SE, and you're done... and that saves you the eye-burn of even trying to read the long-form Schedule SE.
You need to file Schedule SE because you are just above the reporting threshold for it. If you had made < $433 (really) *, you wouldn't need to file Form SE. You might want to find some business expenses e.g. travel (transit, or IRS's mileage rules), or double-check your numbers.
Paying SE tax isn't all bad. When you retire, your social security benefit is decided by how much money you made while working. This posts as income for that purpose.
Support
From Pub. 525 (IRS's deep-dive guide into what income is):
Sharing/Gig Economy
Generally, if you work in the gig economy or did gig work, you must include all income received from all jobs... See the Instructions for Schedule C (Form 1040 or 1040-SR) and the Instructions for Schedule SE (Form 1040 or 1040-SR).
From Sched. C instructions:
Use Schedule C (Form 1040 or 1040-SR) to report income or (loss) from a business you operated or a profession you practiced as a sole proprietor. An activity qualifies as a business if your primary purpose for engaging in the activity is for income or profit and you are involved in the activity with continuity and regularity.
The only "out" Schedule C gives you is if the activity is "sporadic", then it may not qualify as a business and could be reported on Sched 1 Line 8. But I doubt that applies since you are presumably open to more tutoring business if you can get it. Even if you could argue that, and get that argument to stand up in an audit, I still wouldn't bother -- you still have to deal with Schedule SE; and the Schedule C path is the easier way to do that.
The only other out is "hobby". I hang out with hobbyists who regularly try to "game" the difference between hobby and business, either to deduct hobby expenses or evade SE tax on work. That trick never works. IRS is wise to it, and will quickly refuse you, alter your return, notify you of penalties and interest, and say "if you disagree, sue us. Here's how."
My friends make the mistake of wrapping themselves up in self-justification. But the fact is, IRS uses the plain-English version of "hobby". From the IRS Small Business FAQ:
A hobby activity is done mainly for recreation or pleasure.
What matters is how a cool outsider sees it. Its it a hobby or business for most people who do it? Is the lion's share of your activity conducted in a hobby manner (i.e. as a passion project)? Sometimes (not here), that's a tough noodle to stick to the wall, and that link has more documentation to help you determine; but never forget the core definition above.
  • Here's a dog that won't hunt: "Tutoring is a lifelong avocation that I only do when I'm paid".
You will not deal with anyone willing to listen to your argument until you sue IRS. Having done this and won, I can tell you it's a waste of time unless you have a strong understanding of Tax code and can coherently argue the law (and present provable facts). I would not want to argue tutoring as hobby.
Given that tutoring for pay is a classic student job... and OP, you give no evidence of tutoring as a passion project... I see any "hobby" claim as undefendable. Hence I don't advise it, and have excluded it from my advice. It might work for other readers if their facts support it, but don't fool yourself.
* Really. $433 not $400. Punch $432 into Schedule SE and see what happens.
Harper - Reinstate Monica
  • 59,009
  • 94
  • 199
Ben Miller's answer is good, but for completeness, I will simply note that if any of your students had paid you more than $600, they would be legally required to report that on a 1099-MISC, per IRS rules. Of course, many folks don't do this, especially if the amount is not much above the threshold. But this would definitely make it important to report the income on your own return. Amounts which do not trigger a 1099, as jamesqf observes, are generally not that interesting to the IRS (which is why you never hear of armed agents storming a teenager's informal lawnmowing business).
Lawnmower Man
  • 1,839
  • 13
