11
Some mates and I have the amount to cover the cost of an item but have a credit limit lower then the price. The purchase has a hard requirement that the payment method is a credit card. So, my mates and I put a negative balance on the card (I.E: The balance is 0 and then we pay something like 16,000 on it, making the balance -16,000 so we can make the large purchase putting the -16,000 balance back to 0).
Could we make the purchase using this method?
Nosjack
  • 10,866
  • 30
  • 58
x7309wh
  • 113
9 Answers9
29
Ultimately, in order to answer this, you need to check your cardholder's agreement, and/or call your issuing bank and ask them. Card behaviors around credit balances and purchases larger than your limit will vary from bank to bank.
Most banks will be happy to let you carry a credit balance (after all, that's essentially you lending them cash for free), but by regulation they are required to make a good-faith effort to refund your money within 6 months. Few banks will take action before that limit without you prompting them to (i.e. explicitly asking for a refund). However, it sounds like you plan on implementing this "immediately" before making your transaction.
You may run into issues with this, as some issuers implement a rule that says that no single transaction can be equal to or larger than the credit limit on the card - even if you have a credit balance, you can never charge more than the limit. However, other banks are totally happy allowing that to happen if you have a credit balance large enough to keep the balance under the limit.
So - call your bank and ask. Or, ask the merchant if you can split the transaction into several smaller ones. Or, call your bank and ask for a higher credit limit.
dwizum
  • 17,100
  • 44
  • 61
Most credit cards (at least here in the US) do have the concept of temporarily raising a credit limit for a purchase. It's always by request, and there's no guarantee of approval, so you would have to try and see. If the amount is grossly different from your current limit it will probably be a challenge unless your credit score and income have dramatically improved since they put your limit in place.
If you can't get a limit increase, then as Aganju suggested, finding a friend or family member with a high enough limit and giving them the money is probably a good bet.
I know I'd be happy to earn cash back for such a large fully-reimbursed purchase.
One other thing I want to add. This purchase sounds.. somewhat sketchy.
What merchant would pay credit processing fees on a high amount when a buyer is willing to pay cash/bank transfer?
What merchant would be willing to accept a single credit card payment for such a high amount but not allow splitting among several cards (the per-transaction fixed fee would be negligible at high dollar amounts where the percentage-based fees would make up the bulk).
briantist
  • 3,024
  • 18
  • 19
Typically, that does not work. Calling the bank might give you different info, but there is a risk that it won't work, even though the bank explicitly confirms it (happened to me, BoA). At the end, the original credit limit of the card applies, even if you overpay it with a million.
You can try to call and ask for a limit increase, even only temporarily; the risk with that is that your credit score might probably go down, and it might get declined, so you end up worse than before.
Also, once you transfer the money onto the credit card, it takes a lot longer to get it back. The official claim is typically '4-6 weeks', but it might work in 10 days if you are lucky.
My solution was to take out cash and hand it to a (personally and well-known!) friend, who had enough limit on her credit card and made the booking for me. The bank impressed only by being extraordinary disinformed, self-contradicting, helpless, and counterproductive.
Aganju
  • 38,107
  • 59
  • 121
In contrast to @ChrisInEdmonton's credit card, my credit* card does allow such charging. It does have additional spending limits per purchase/per day etc, so I'd probably have to ask my bank to raise the limits for the foreseen transaction.
* I'm in Germany, and my credit card (like many credit cards over here) look from the outside (e.g. the store where I do a purchase) like a credit card but internally work mostly like a debit card with a comparatively small credit.
cbeleites
  • 3,024
  • 14
As others have said, it depends a lot on the card issuer (and country), and by experience, it can vary with time as well.
I used to put a very large credit balance on one of the Amex cards I had, in order to have the ability to pay amounts much larger than the credit limit on that card (I wanted to use that specific card for some miles-related reason I don't remember).
This worked very well for months, until one day when I was at the other end of the world they called me to tell me they couldn't accept that any longer, and they immediately refunded the credit. Which was quite annoying as I suddenly couldn't pay some large bill exceeding the limit with that card.
As far as I understand it, Amex have made explicit changes to their T&Cs for at least some cards to make it clear they don't want you do to that (they may even reject payments that would make your balance go into credit).
Your best option is to see if you can pay the amount through other means. Most merchants would actually much, much prefer a bank transfer over a credit card payment any day of the week for such an amount: credit card fees for $16000 are usually several hundred dollars. Also, a credit card payment is much more likely to get a "chargeback" (cancellation/dispute) than a bank transfer.
Your next best option is to call the card issuer to ask whether they can either increase your limit or accept an overpayment AND that overpayment would actually add to your total limit.
jcaron
  • 4,112
  • 16
  • 29
I'm not really clear why you don't just use a Visa Debit card for this purchase? I use Visa Debit for expensive purchases like long-haul international flights, hotels and health spas or whatever. It's really easy - I just transfer $12k or so into that account and then start spending. You can just put your $16k onto a Debit card and pay that way.
There are no monthly fees, and best of all, it is still backed by Visa just like a credit card. What I mean by that is, recently I was travelling around Europe and a dodgy vendor charged my card for 200 Euros that I didn't spend. The vendor didn't respond to my emails, so I complained to Visa and they reversed the payment. So you're just as safe using a Visa Debit as a credit card, and I never get stuck paying interest or late fees because I never owe Visa money. Debit cards are the best - I haven't owned a credit card in years.
Only_me
  • 120
Probably not. It may depend on your credit card, but I know for sure my credit card doesn't allow this. If you have a credit limit of $10,000, your credit card may not allow you to make a purchase greater than $10,000, even if you've prepaid several thousand in advance.
What you may be able to do instead is to pay for the item over several days. That worked for me.
ChrisInEdmonton
  • 14,143
  • 45
  • 75
You can possibly find a prepaid credit card. This is a card (in the USA, generally Visa or MasterCard) which looks to the merchant like a credit card, but from your viewpoint is one where you deposit money in advance, and any charges are debited against your existing credit. I have never used one, but if they work logically you should be able to deposit 16,000 of whatever currency you use, then charge that amount. Here's one list of potential vendors: https://usa.visa.com/pay-with-visa/find-card/get-prepaid-card
CarlF
  • 231
It seems that it depends by bank.
In Argentina, I can overpay or "charge" my credit card.
If you go to Visa Home page, there is an option "Balance status" (or so).
There you can see Available to make purchases: XXX, Available to make purchases in installments: YYY
When I tried this, the only amount that increased was the first one, i.e the amount that you can use to make a payment in one payment only (no installments).
JorgeeFG
  • 131
