I was thinking about this as I was writing a comment for this question. I wanted to make a point that is the OP paid his credit card in full before each month's statement was generated (so that the statement balance read $0) then that is the amount that would be reported to credit bureaus. The point would have been that even if I had the means to pay a $x balance in full each month, financial institutions would probably look more favorably on a $0 balance being on my credit report.
My question is - is a credit report actually the source of truth for debt to income calculations? Am I mistaken and instead the consumer is trusted to furnish accurate information? Does the underwriter or whomever actually call the owner of each debt that is listed to confirm the current amount and minimum payments?
I'm thinking in the sense of a mortgage application but if the underlying purpose of the DTI calculation will affect the answer, I'd like to hear about it.
Philipp
  • 24,257
  • 56
  • 76
Brian R
  • 1,876
  • 15
  • 15
You asked a few related questions:
Before answering, we need to consider context. In some cases, lenders will calculate portions of DTI based purely off consumer-supplied data. Typically, this is for quicker, lower-risk use cases. For instance, you're at a big box store, applying for their store-branded credit card. They aren't going to ask you for five years of tax returns and six months of pay stubs in order to determine your income - they're going to give you a form with a box that says "income" and you're going to write in a number.
However, if you're considering a use case where more risk is involved, there will be more scrutiny. Generally, consumer-supplied data will not be trusted without backup. You mentioned mortgage applications. That's a great example of a case where there is more scrutiny. Typically, in a mortgage application process, you will give the lender permission to pull your credit report. They will use data on the report to calculate the debt side of your DTI. For mortgage applications, the DTI is typically calculated on a monthly basis. Any credit account you have on your report will be included, based on the monthly payment amount shown on the credit report. Since you mentioned credit cards, the monthly payment amount will be the minimum payment due that the card issuing bank reported, on the day that they reported your account to the bureau. So, if you typically carry some balance on your card (i.e. you use it throughout the month), but you pay it off every month, that amount may or may not reflect that behavior. For instance, if you make a few charges and immediately pay them off, you may actually see a zero reported for that card. But if you pay it off once a month, you may see a minimum payment reported, which will be included in the calculation.
Short story: In the case of a mortgage application, for the Debt side of DTI, your credit report is treated as the source of truth.
In terms of income, for conforming mortgage loans (those that meet Fannie/Freddie standards), you will be asked to provide two years of tax returns, plus current pay stubs, as a way to validate your income. It's important to point out that credit reports from the major bureaus do not include income information - so any time a lender wants to calculate DTI with rigorous backup, they will need some proof of income even if they're pulling your credit report.
To address one of your other questions,
No, that definitely doesn't occur - essentially, credit reporting exists to alleviate the need to do that.
And, as a footnote, it's worth pointing out a correction to one of your assumptions:
That's not inherently true. Card issuing banks will generate bills on a fixed monthly cycle (i.e, your bill may be generated on the 15th and due on the following 1st), and they will generally also send data to credit bureaus on a fixed monthly cycle - but those two cycles don't inherently align (following on the above example, they may send data to the bureaus on the 29th of each month). So, the data that is sent to the bureaus may not exactly match what shows on a given monthly statement.
dwizum
  • 17,100
  • 44
  • 61
Here's the SOURCE MATERIAL FOR the ATR/QM Rule. If you really want to read about the long version as to why, here's some documentation on that subject. I'LL DO ANOTHER POST ON HOW TO CALCULATE IT DOWN BELOW.
ATR/QM Rule
In January 2013, the CFPB adopted Ability to Repay/Qualified Mortgage Rule (ATR/QM Rule) that implements the ability to repay provisions of the Reform Act. The ATR/QM Rule generally applies to closed-end consumer credit transactions that are secured by a dwelling on which an application is received on or after January 10, 2014.
The ATR/QM Rule generally imposes an affirmative obligation on mortgage lenders to document a customer’s ability- to-repay whenever a covered residential mortgage loan is made. The ATR/QM Rule provides certain legal protection from suitability challenges with respect to loans that are treated as qualified mortgages (QMs).
The ATR/QM Rule fundamentally changes the U.S. residential mortgage finance market from one that is largely based on a disclosure liability standard, to one that is focused on the suitability of the loan for the borrower. This significantly rebalances the legal relationship between the lender and its borrower. The citations for this Unit are from 12 CFR Chapter X, Subpart E, §1026.43(a–d) and the accompanying Commentary 43(a-d)].
Covered Transactions The CFPB’s ATR/QM Rule applies to covered transactions. Covered transactions include almost all closed-end consumer credit transactions secured by a dwelling including any real property attached to the dwelling. [12 CFR §1026.43(a)]. A dwelling means a residential structure that contains one to four units, whether or not that structure is attached to real property. The term includes an individual condominium unit, cooperative unit, mobile home, and trailer, if it is used as a residence. [12 CFR §1026.43(a)(19)]. Unlike some other mortgage rules, the ATR/QM Rule is not limited to first liens or to loans on primary residences. A loan modification is considered a covered transaction only if it is considered a refinancing under Regulation Z. Therefore, MLOs should find out if a loan modification is actually a refinancing because if it is, the ATR/QM Rule applies. Some loans are exempt from the ATR requirements.
General Requirements of QM Loans: Qualified Mortgages have three types of requirements: restrictions on loan features, points and fees, and underwriting. QMs generally cannot contain certain risky features (such as allowing interest-only payments or negative amortization). For a loan to be a QM, the points and fees may not exceed the points-and-fees caps. The points- and-fees caps are higher for smaller loans. For a loan to be a QM, the borrower’s total debt-to-income ratio is not higher than 43%. [12 CFR §1026.43(e)(2)(i-vi)].
Skipping straight to underwriting:
Types of Qualified Mortgages The types of QMs are General QM loans and Small Creditor loans.
Type 1: General QM definition
General QM loans may not have negative-amortization, interest-only, or balloon-payment features or terms that exceed 30 years. They also may not have points and fees that exceed the specified limits. [12 CFR §1026.43(e)(2)]. In addition, in order for a loan to be a General QM loan, the creditor must:
• underwrite based on a fully-amortizing schedule using the maximum rate permitted during the first 5 years after the date of the first periodic payment.
• consider and verify the consumer’s income or assets, current debt obligations, alimony and child-support obligations.
• determine that the consumer’s total monthly debt-to-income ratio is no more than 43%.
Laythesmack
  • 189
