I am currently using MS Money for tracking my finances, and would like to switch to an online solution that I can access from anywhere.
The problem is, I don't really trust some website to have access to my accounts and transactions. I would like to use a software that I can host on a server I have full control of.
So here are my requirements:
  • the software can be installed on a Linux/BSD server, preferably open source, but not required
  • works on major browsers on Windows, Mac and Linux.
  • secure (should work over https)
  • can import transactions from banks. It is acceptable that I have to manually download statements from my bank and then import them into the software.
  • (optional) can import transactions from MS Money.
Is there anything like this available?
Miguel
  • 331
I generally concur with your sentiments. mint.com has 'hack me' written all over it.
I know of two major open source tools for accounting: GNUCash and LedgerSMB.
GNUCash
I use GNUCash, which comes close to meeting your needs:
  • can be installed on Linux/BSD server and connects to mysql/postgres
  • secure SQL connection
  • can import transactions from banks via OFX and HBCI or QIF
  • (optional) can import transactions from MS Money if you export to QIF
The 2.4 series introduced SQL DB support; mysql, postgres and sqlite are all supported. I migrated to sqlite to see how the schema looked and ran, the conclusion was that it runs fine but writing direct sql queries is probably beyond me. I may move it to postgres in the future, just so I can write some decent reports. Note that while it uses HTML for reporting, there is no no web frontend. It still requires a client, and is not multi-user safe. But it's probably about the closest to what you what that still falls under the heading of 'personal finance'.
LedgerSMB
A fork of SQL Ledger, this is postgreSQL only but does have a web frontend. All the open source finance webapps I've found are designed for small to medium busineses. I believe it should meet your needs, though I've never used it. It might be overkill and difficult to use for your limited purposes though. I know one or two people in the regional LUG use LedgerSMB, but I really don't need invoicing and paystubs.
jldugger
  • 7,437
  • 35
  • 57
-2
You can use www.mint.com for most of your requirements. It works great for me, it's free and I'd say is secure. Hosting that kind of service just for your will be time-consuming and not necessarily more secure than most of the stuff that is readily available out there. Good luck.
jasonco
  • 97
