Compressed air cars are not generally available, because the technology suffers from a fatal flaw. Compressed air cars are charged simply by compressing air, but the charging is done many hours or even days before the car is driven.
When air is compressed fast, it undergoes adiabatic compression. Part of the energy is stored in the compressed air and part of the energy is stored into heating the compressed air.
Because the charging is done many hours or even days before the car is driven, the heat in the compressed air has time to dissipate. So although the fast charging was done with adiabatic compression, the end result is similar to isothermal compression, in that the temperature at start and at end (after heat dissipation) is the same. I'm not experienced enough in thermodynamics to say whether it's only similar to isothermal compression, or actually equivalent to isothermal compression.
Then when the car is driven, the energy in the compressed air is utilized very fast. It undergoes adiabatic expansion where it cools. The problem is, this cooling robs the efficiency of the compressed air engine. Also because the expansion is adiabatic and not isothermal, the part of the energy that was lost into the heating of the surrounding environment is lost forever.
If a car is driven very slow, let's say at walking speed in level ground, theoretically the energy usage rate could be so low that a very big heat exchanger could change the adiabatic expansion into isothermal expansion, where the expansion is able to utilize the heat that was lost into the surroundings again.
But that's not how cars are driven. Cars are driven often very fast, often up hills too. Acceleration of the big >1000 kg object is fast, so lots of energy is used in a very short timeframe. There is no big enough heat exchanger that could allow isothermal expansion to happen quickly enough. So it's adiabatic expansion only, and adiabatic expansion doesn't utilize the part of the energy that was lost to surroundings as heat.
Compressed air systems have been used in grid energy storage. According to Wikipedia, the McIntosh, Alabama compressed air grid energy storage system requires 2.5 MJ of electricity and 1.2 MJ of natural gas used for reheating for 1 MJ of energy output. That's a terribly poor energy efficiency, even lower than hydrogen vehicles. Note the natural gas for reheating is necessary, since some way to heat the cooling expanding air is needed.
Because of this need for heating, a compressed air energy storage system should be viewed only as a more efficient way to utilize fuels, not as some fuel-free way like what electric batteries are. And if you already have fuels on board, it's just simpler to use those fuels for all of the propelling energy.
