Recently, and not all the time, the wiper arms on my car are so weak that they get stuck on the last wipe of a screen wash 'job'. At first I thought it was friction with the window, but I've since tested by holding the wipers away from the window with my hands while the arms try to move it. I can feel with my arms holding the wipers that the wiper's arms are struggling to move the whole thing.
Inexplicably - other times they're fine.
I don't quite know whether it's purely mechanical, or relies on the battery, or involves rubber pulleys. Before I reluctantly take it to a repair garage (where they might quote for an expensive complete system replacement) I thought I might ask here to see if there is any knowledge of how these work in my model of car.
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
MrVimes
  • 275
I had the same problem with my 2006 Jaguar S-Type. It turned out to be the bolt that attached the wiper arm to the chassis was very loose.
VLBRWR
  • 31
Double wiper blades are sometimes the issue.
GettingNifty
  • 483
  • 13
I wouldn't recommend this solution generally, but I'm providing it here as it's what fixed it for me.
I sprayed liberal amounts of WD-40 into the area of the mechanism, and eventually the wipers started to move freely. They've been fine ever since.
I realize this is a seemingly obvious solution, but I did try WD-40 initially and it didn't work. It was only after spraying loads of it in frustration (some time later) that the wipers started to move freely.
MrVimes
  • 275
