I was replacing the alternator on my 2014 Ford Fusion 1.5L, mistook the crankshaft pulley bolt for my tensioner. At first I rotated the crankshaft pulley bolt CW before realizing it was the wrong bolt when I saw the serpentine belt moving CW, so then I rotated the pulley bolt CCW thinking I could put it back where it was. I used a breaker bar to do this, the serpentine belt & alternator were still installed & the crankshaft pulley bolt & serpentine belt spun fairly easy in both direction. I could feel what I think is compression build then release as I spun the bolt. but I dont know it thats normal. Now I'm concerned my timing may slip & damage my engine once I start the engine. Did I mess up my timing? If so, what can be done to adjust the timing? I called some local shops, several say they can replace the timing belt but don't know how to fix the car since I rotated crankshaft pulley bolt CCW, one said they had to tear down the engine@@, dealership said they'll replace my unbroken timing belt for $1200 because that's what the standard labor cost is-- all that seems kinda sus! If he said BC its time to replace or they'll replace BC they have to remove it anyways--Ok but just BC, that sounds sussy!!
Idk what to make of this, car has 86k mi. had it 7 yrs as sole owner, I think belt replacement recommended at 60k mi. but runs fine, always seems to misfire- its a Ford:/
The internet / YouTube seem to be failing me so far because people say don't do it but no one has said what happens when you do rotate the crankshaft pulley bolt CCW. It's like saying don't touch the big RED button, but either you or you know someone who's hit the RED button so tell us what happens! Would like to give this starter car to my daughter. If there was ever a time for the Internet to show up, this is it, please help.
