Need to get power to battery so i can use fob
Asked
Active
Viewed 234 times
Well you cant get in without breaking stuff .If you can charge the battery then you can hop in normally because the central locking receiver and soleniod will open the door .You can connect the neg black clip of your battery charger to the car body somewhere because all cars these days are neg earth . Now the pos red lead can be clipped onto the starter motor when you get under the car and have a look or use Dr google for drawings .The battery always goes direct to the starter motor via a heavy easy to find cable .Now you can connect your charger and you should see some current on the dial ,Wait a hour or 2 and hop in with your fob.
Autistic
- 2,118
- 1
- 19
- 27
