The chart on top is what I found more commonly on the internet, but the chart at the bottom is used by a YouTube mechanic I like. The numbers on these two charts deviate quite significantly. For example
at 85 Fahrenheit, the top chart says 45-55 psi on the low side. 225- 250 psi on the high side. the bottom chart says 27-42 psi on the low side. 128-181 psi on the high side.
At 105 Fahrenheit, the top chart says 50 - 55 psi on the low side. 330- 335 psi on the high side. the bottom chart says 37 - 52 psi on the low side. 196-246 psi on the high side.
Which one should I trust if I decide to recharge my refrigerant?
It's the summer, it's really hot without a working AC. Your help is much appreciated!
