I had a custom exhaust slapped together on my car several years ago. Recently, it started running badly. I noticed that the rubber hose connecting the catalytic converter to what I believe is the EGR tube had split. I got the hose off and went to the parts store to find a replacement. The guy at the parts store told me it was coolant hose (Gates Blue Line) and had no business being on the exhaust. I only drive the car a few hundred miles per year so that's probably why I've gotten away with it for so long. What can I replace this with? Given that I got years out of that one hose, I'm not against replacing it with the same and treating it as a consumable but I want to do it right if possible. I do not have the ability to weld.
The hose was about 10 inches long and 3/4" ID. The EGR tube is 3/4" OD, the catalytic converter's outlet is 1/2" OD. The hose was cranked down with a hose clamp and some hardened foam-like material over the catalytic converter's outlet to bring it down to size. Attached is a picture of where the hose was.
