I have a coleman ct100u mini bike that has gas running to the carburetor but is not being sent to the engine. I have installed a new carburetor and clean all of the jets and nothing happened. I took the new one off and cleaned the old carburetor and same thing. When you pull the cord several times and then pull the spark plug out it is dry and not receiving gas.
Asked
Active
Viewed 125 times
Did this problem occur suddenly or after sitting for a long time?Remove the carburetor bowl and check for gas in the bowl.If no fuel in bowl the problem is either the needle and seat clogged, or the float is stuck.Basically,the problem is upstream from the carb if it has no gas and the above issues have been tested.
honcho
- 1
- 1
