Briefly
I'm reaching the conclusion that the different trim levels offered for the same model of the same car brand do not have the same rolling diameter (and hence their Revolutions Per Mile—or rpm, the other rpm—is different). This is wild to find out, because it means that unless calibration is done from one trim to the next (and that's highly unlikely), the speedometer will be giving just a rough estimate of the speed.
Confirming that different car trims have different rolling diameters
Extended Version
Let's look at this through an example. One model of one brand has multiple trim levels (like most). (I selected a particularly gigantic car to get numbers that are spread further.)
One of the differences between these trims are wheels of a different size. Instead of 265/50R20 for the base trim, the highest trim gets 275/40R22 wheels.
Calculating the rolling diameter should be pretty elementary, and so we need not go to a "tire size calculator" web site to do this.
265/50R20 diameter = 2 * 265 * 0.50 + 20 * 25.4 = 773.0 mm
275/40R22 diameter = 2 * 275 * 0.40 + 22 * 25.4 = 778.8 mm
This means that the higher trim has 5.5 mm larger rolling diameter than the lower one.
My real objective is the fourth question below, but feel free to comment on any—including simply the one in the subject line (the one "official" question).
- Which of the two is taken into account by the speedometer? Is it just an average, and the speed indicated is anyway just a rough (+/-2%) measure?
- Do (modern) cars have any way of determining the wheels installed? (The pressure is, after all, transmitted wirelessly.)
- Is this entered at some stage of calibration and before delivery?
- Does this mean that the end user who selects rims and wheels of a different size needs to go back to the dealership to recalibrate the speedometer?
Related
Chronologically:
- Using different rim that what I have?
- What is the effect of changing rim diameter while keeping wheel width constant?
- Can I use a different diameter tire size on my current wheels?
- Can summer and winter wheels be of different size for the same car?
- Considerations for downsizing wheel diameter
