2010 Silverado 1500
My Silverado has an empty spot under the hood for a second battery. I’m wondering if I could install a second battery and use it to power a winch that is mounted to the headache rack in the box of the truck. The winch is used to pull an aluminum boat and trailer up off-road boat launches.
As a novice, I’m wondering if the ideal battery wiring might work like this:
- The battery would get automatically charged when the truck engine is running, ensuring the battery is always charged before winch use.
- The truck could be running or turned off when using the winch. Only the second battery would get used by the winch. The primary battery would never get drawn down by the winch, avoiding a possible dead primary battery scenario where the truck wouldn’t start.
Is that kind of wiring setup possible? If not, what is normally done?
