I'm watching this repair video that replaces the AC Compressor and I'm exploring how feasible it is to just replace the o-rings on the hose and compressor side of the AC Compressor's ports.
I'd like to know what would physically happen when you disconnect any of the AC hoses as installed on a vehicle's AC compressor.
I assume they're under pressure and would leak refrigerant and or oil immediately upon disconnection, but I'm curious would all the refrigerant leak out? Basically do these hose fittings have any other seal/valve-mechanism beyond the o-ring or is it just the o-ring? I'm thinking of something analogous to a manifold gauge set that has that fitting you have to slide back to fit over the low pressure and high pressure ports, or something like a Schrader valve with a core that gets depressed when you engage the hose to the compressor. Is there anything like that on the hoses themselves going to the compressor or not really?
unbolting AC hose from compressor
jxramos
  • 1,880
  • 34
  • 49
If you pop the hose or any of the connections, you lose most all (if not all) of the refrigerant. It is under significant pressure. Enough you cannot get things sealed back up before it's gone.
In order to do work properly on an AC system, you should have the refrigerant removed. Purposely venting it to atmosphere is actually illegal in most places. When you are done with your repairs, then you have the refrigerant replaced with new.
I'm not sure the gist of what you're trying to do, but I try to wrench by one saying, that is: If it ain't broke, don't fix it. What does that mean? If the something you are trying to fix works perfectly well in the first place, it doesn't make sense to try and fix it, because you are only wasting money. From the sounds of what you are talking about, you are thinking about changing out o-rings just for the sake of changing them out and not because there is any real issue with them. My suggestion is, if this is what you're thinking of doing, don't. It isn't worth it.
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
jxramos, did you watch that video from the beginning? In the first minute, the presenter warns viewers to remove refrigerant before any repairs, suggesting a local repair shop. Legally, refrigerant must be removed into reclamation canisters (15/30 lb capacity canisters labeled for reclamation) by licensed repair shops abiding by EPA regulations since they're likely to perform many repairs to vehicle ac systems. However, in reality, leaks release refrigerant that no one can control when it occurs. Again, refrigerant must be removed before repairs begin as standby pressures (ac off, ambient temperatures) vary more or less direct proportion to outside temps. 75F/75 psi, 95F/95psi - sealed system pressures. When running, high side pressures can easily exceed 200 psi - not diy friendly when attempting to monitor pressures without familiarity about hazardous conditions around working ac systems. The two service valves are for anyone familiar with using gauges and the eventual repairs needed when ac fails. Disconnecting any ac fitting without understanding standby pressures can result in an immediate high pressure (approximately 75 psi) discharge of refrigerant and oil to blind anyone not wearing eye protection. It's said that FAA regulations related to flying are paid by the blood of accidents and crashes and the investigations to uncover the causes and make recommendations to prevent repeating mistakes. Vehicle ac repairs are no different with safety procedures already well known to allow anyone a safe procedure when working on ac problems.
Because sealed ac systems will leak, eventually, knowing what refrigerant remains determines if its safe to open fittings with an empty system or removing the bulk of it into a reclamation canister using gauges and (electric) vacuum pump. Repair shops not using reclamation canisters can be fined thousands of dollars for allowing release of refrigerant into the atmosphere. Diyers discovering their empty systems already released refrigerant are generally not subject to being cited for inadvertent leaks. Once a system is depressurized, fittings can be safely disconnected. Since oil circulates freely throughout a system, you're likely to find oil (and dye if installed at factory assembly) on your hands. Repairs must be kept clean to prevent debris from getting into a system that can accelerate compressor wear. R134a O-rings are prelubed with r12 mineral oil - it doesn't absord moisture.
Once you become familiar with diagnosing and troubleshooting your system, the reason for replacing seals may not be as simple as it appears. R134a systems use pag oil that readily absorbs moisture. A leak will release refrigerant, dye and oil, attracting moisture to the leak area. Moisture will begin to corrode bare, untreated aluminum parts in every ac system. This can erode the precise fitting surfaces in each fitting that mates to allow the O-ring a leak free seal. Corrosion allows uneven protrusions preventing proper sealing against pressures. Fitting faces should be at least free of any corrosion preventing re-sealing with new O-rings. Guess how I know? Overtightening of aluminum fittings or replacing seals will not correct for corrosion. Remember, fittings on the high side (discharge side of compressor, hose, condenser coil, receiver/drier, hose to input side of the thermal expansion valve, will be under pressure between 125-250 psi. While ac systems are not rocket science, familiarity is needed to work on them. I like the analogy; if you do not understand super or turbo chargers, then it's not a diy friendly repair if it breaks down. The same for vehicle ac systems.
F Dryer
  • 1,688
  • 16
