I've been doing some repairs and now that everything is in place I can't get it to start. I start classically with the key, and in this case, the key turns only a quarter of the way and it doesn't go any further. At the same time, when the engine was running, the key was turned 180 degrees. So, when you press the clutch and turn the handle, the warning lights come on classically, and when you press the key again, it clicks, but the car does not start.
I already had a similar problem in the past, but the service desk told me it was the spark plugs. Then the battery and electrical circuits were fine, I started the car with an external starter, it drove normally, but it did not start by itself. Of course, I can test the battery again, and go through the fuses and electrical circuits, but I'm wondering if the problem is the anti-theft safety lock, like in this video. The car, just like last time, locked the trunk, which smells like anti-theft insurance to me.
What I did was disconnect the front fender panels and the left rearview mirror and also disconnect the battery circuit.
