I’m having problems with my Toyota RAV4. I bought the car 6 months ago with a lambda sensor fault. By time I got it home, had lambda bank 2, sensor 2 and Mass airflow sensor faults. Changed both, okay for 300 miles then had lambda sensor bank 2, sensor 1. Changed this and was fine for 5 miles then back to original lambda sensor fault.
It’s failed MOT by emissions. CO @ 6.81%. should be max 0.3% HC @ 459ppm should be max 200ppm Lambda @ 0.82 should be 0.97-1.03
The CO is x20 what it should be… I’ve had it in 3 garages, electrical specialists. Had wiring harness checked, put as close to OEM lambda sensors in, checked for vacuum leaks. Just going round in circles with the fault codes and changing sensors
What do I do?
