I'm working on a 98 Dodge Ram 2500 with a Magnum 360 V8 (roller cam shaft). It had a cracked head on one side, so I purchased a pair of remanned heads from an eBay retailer. These heads are the 466/671 combination (as expected). The problem is, the heads which I pulled off are an identical set (both 466 heads - this engine has had head work done before, obviously). I need to know which one goes on which side (driver's/passenger). I read on a couple of different sites which say they are identical, which I am doubting. The reason I am doubting is due to the fact everywhere I've looked, it specifies for different heads. (If they are exactly the same, or interchangeable, why would they make and specify two different heads??). I've seen one site (actually a seller) which actually specifies which head is supposed to go on which side, but it uses right/left. I have a major problem with this, as some people view right/left while standing in front of the car, while others use the view as sitting in the vehicle. Driver side and passenger side are much more descriptive. Also, if anyone knows what exactly the differences are, it would be appreciated.
Asked
Active
Viewed 1,608 times
After an exhaustive search on the internet, I came to the conclusion that while the two heads have a different part number and are different in some very minor ways, I have just thrown the heads on there and done the deed. If there is a significant difference I couldn't see, there doesn't seem to be an issue with them. The truck started right up without any leaks or problems with the heads that I can tell. It is my understanding (now) that it doesn't matter which head goes on which side.
Pᴀᴜʟsᴛᴇʀ2
- 165,084
- 32
- 259
- 508
-1
The heads are the same, left or right When it is stated left on the vehicle it means that when you are sitting in the driver's seat, not when looking at the vehicle from the front.
