Where is the power steering return hose on a Hyundai Santa Fe? Is there a diagram somewhere that shows how it is run?
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
Mark Perko
  • 41
You should be able to easily find the return line. There are two lines which should be going to your power steering pump. One would be the high pressure side going out to the steering rack. It will have pressure fittings on it. The return side is low pressure and will be attached to the pump via a hose clamp. An alternative to this would be if there is a separate reservoir from the pump. Here, the return line should be towards the top of the reservoir and feed towards the bottom of it.
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
