24
I have a 2005 Subaru Legacy 2.5i Wagon.
I just destroyed the passenger-side rear tire.
The tires have approx. 6/32" tread remaining, per an informal measurement with a coin (I used this guideline from tirerack.com)
These are Nokian tires, and according to the specs I found online, they have 11/32" tread depth when new.
Another article on tirerack.com on this topic, suggests that Subuaru states that the differential among tread depth should vary no more than 2/32"
My owner's manual does not specify the what difference in tread depth tolerance is, however they do point out that I have a dashboard indicator "AWD" that will flash if the vehicle is driven with tires of different diameters, and I assume, the drive train is in danger of being damaged.
Among my family and friends, I've received conflicting opinions regarding whether I should replace all 4 tires immediately, or if I could potentially purchase the same brand and model of tire, whose tread depth, I assume, would be 11/32" and be different by approx. 5/32" from the existing tires.
Does anyone have a definitive answer as to which option I should choose?
Is it true that tread-depth can influence tire circumference enough that driving my Subaru for an extended period of time would damage the drive train?
CONCLUSION: I chose to replace all 4 tires with new tires, and I'm happy I did.
Hᴇʀʙɪᴇ
  • 3,737
  • 36
  • 67
qxotk
  • 424
I do: you need matching tires.
That said, it's your car and you have to make the decision. I'd tend to replace all four. @Paulster2 also makes a good point that you could shave down a new one to match.
Let's start by looking at one of the most useful paragraphs from the Tire Rack article that you cite:
Four-wheel drive and all-wheel drive vehicles are equipped with additional differentials and/or viscous couplings that are designed to allow momentary differences in wheel speeds when the vehicle turns a corner or temporarily spins a tire. However, if the differentials or viscous couplings are forced to operate 100% of the time because of mismatched tires, they will experience excessive heat and unwarranted wear until they fail.
What that means is that a mismatched tire won't break your drivetrain immediately. It's more subtle than that: at least one differential will be loaded all of the time and at all operating speeds. So, instead of managing the different rotation speeds in a relatively low speed turn, you'll be cooking your differential at highway straight line speeds.
It's good that there's a light but, frankly, you can hear the differential being overworked if you listen for it. On my Subaru, if I inflate the rear tires to match the front tires' pressure (approximately 4 psi up), I'll hear a distinctive high-pitched whine from the center differential every time I coast down from speed in second gear.
Note: my car is a manual transmission WRX. You may have different audible symptoms in other vehicles and transmissons.
In the end, the reason that the tires should match is the same reason that you shouldn't tow an AWD car (instead they should be flat-bedded). If the back wheels are turning at speed for miles but the front ones are not, the center differential will burn itself up in short order.
Is one mismatched tire that extreme? No, of course not. It will wear your differential, make worrying sounds and affect your handling.
You still have to make the call, though.
Bob Cross
  • 24,537
  • 85
  • 166
I had the same issue. One tire needed to be replaced, tire store told me I had to replace all 4. Not wanting to give up good money for no reason, fearing they were just trying to get more money out of me, research led me to replace all 4 for better peace of mind and for a longer lasting Subaru. But the tire place did tell me if I purchased the insurance on the tires, if one tire is destroyed they have to replace all 4 for free. So call me a sucker, I purchased the insurance. But I sleep easier.
P.S. I sell insurance for a living, so maybe that made it an easier sell for them.
Tim
The way I see it is that if that is the case then subaru wouldn't put a spare tire in your trunk if you can't use it. as long as it is the same size from all four then you should be fine. Now if you used a different size tire on it then obviously it would be good for the vehicle. oh ps for the insurance guy ^^ I work at a tire shop.
