basically I bought my Peugeot 207cc last year(make from 2010). The dealership sold it with a faulty TPMS . I have now changed the faulty TPMS and the light still comes up. What can it be? The garage who did said they can't reset it cus of the model of the car is too old for their diagnostic machine or soming like that and also said I have 2 TPMS that give the same code when reading it and apparently shouldn't be? I don'twant to spend 300 odd quid on replacing the rest of the TPMS and still hav the same issue at the end. What else can I do? Even tho I know that MOT failure is only for car models from 2012 onwards with TPMS issues but I still don't want to risk it and it's bloody annoying the warning ligth every time I drive it. Any suggestions?
Thank you
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
The car almost certainly needs to be programmed with the proper equipment to recognize the new TPMS module. If the shop you went to doesn't have the correct equipment, find another one or go to the dealer.
Did you check if the old module could be rebuilt? Usually all they need is a new battery and a gasket or o-ring? That would eliminate the need to get the car re-programmed.
jwh20
  • 12,187
  • 17
  • 27
Some aftermarket TPMS sensors can cause issues so to ensure it works, get OEM TPMS sensors, and have a shop that can program and reset them for you, I would call around couple different nearby shops about it too. Personally I’ve had a TPMS sensor on my Honda accord for 2 years I neglected it lol
Emad
  • 43
