I have a new crank-bolt to install following a timing-belt replacement.
Should I be lubricating this bolt? And if so, what kind of lube should I look for?
No lubrication. Just ensure it is clean and dry (to include the threads on the crankshaft). This will get you the most accurate torque value.
