In spring I had bought a 12V AGM motorcycle battery for a starter for my generator. I had quite some issues making it work and wanted to return it but eventually it suddenly started working. Anyway during summer I used the generator quite often and there were no issues at all.
I have not used the generator much in the last two or three months and it has been really cold (-10/-15°C) when I needed to use it again. I was not very surprised that it was dead and used the hand start. I took the battery home and put it on the charger in AGM mode.
To my surprise after 10 or 15 minutes the charger said the battery is full. I was skeptical but thought maybe it just had to get warm or something. I went back to my generator and besides the solenoid engaging nothing happened. I took it home, put it on the charger again and after around 2 minutes it said again that it is full. To verify if it is potentially an issue with the starter of my generator, I put a car starter on the battery (not connected to a flywheel) and it would not start the motor, however it was sparking when contacting.
I then put the battery on the charger again out of desparation and same thing again, after some 30 seconds it said it's full. I put it on the starter motor again and it started spinning extremely slow and slowing down even more over time until after a couple of seconds it started spinning up very fast until after approximately 5 seconds it managed to reach the usual speed. Since then the battery is properly outputting power again immediately.
Thinking back this is exactly the same behavior I had when I had initially bought it, I just didn't really do it this "systematically" last time until it finally worked.
Does anyone have any idea what is going on here? Apparently the battery is not really defective, the charger is fine as well. The battery just seems to need some sort of "activation" before it operates normally.
