I recently purchased a new SUV with a backup camera. It constantly gets dirty from melting snow, rain, road grim, etc. How can I keep the lens clean, or clean it without causing damage to the lens?
I don't expect anything to be able to keep the lens clean while it is actively ugly on the roads, but I want it to be clean and free from grime when it is dry.
Hennes
  • 589
  • 15
James Jenkins
  • 1,483
  • 20
  • 35
8 Answers8
I cut a 3/4" flat square piece of clear plastic( from vacuum packed purchase of anything),carefully used silicon sealer as a waterproof glue around small trim bezel( mine has flat area around perimeter) ,do not smudge lens view. the flat surface does not trap water/dirt like the convex area of the lens. I found very little intervention is required. I think microscope slide covers 6$ per 100 18mm round would work ,plan on using on all my cars from now on.Can be undone.
POP
  • 31
My current solution:
Clean the camera lens area well, apply a light coating of Rain-x Original. I made sure I had had not left any streaks or hazing, by buffing well.
This was moderately successful, but grim still tended to collect on the lens.
I purchased a new empty spray bottle and filled it with tap water. I park in a heated garage so I was able to place the spray bottle for easy access when parked. When I get home from a grimy drive, I grab the bottle and give the lens area 3 - 5 squirts. I have not had need to physically touch the lens, decreasing the risk of scratching. The picture remains clear when the lens is dry. I have only been using this techinique for about 3 months so can not speak to the long term reliability of it. I suspect that there is some risk to the camera/lens from being subject to "mini power-wash" on a regular bases, but so far the benefits of clear view have outweighed my anxiety of potentially having to replace the unit.
On the few occasions that I did not spray off the grime immediately on arriving home, I have used a few extra sprays with good results, but spraying clean while still wet has shown the best results.
Edit A couple years later, spraying the lenses when I pull into the garage continues to be a fine solution.
James Jenkins
  • 1,483
  • 20
  • 35
I also have an SUV with backup camera, camera in the forward direction and two downwards cameras on the door mirrors. My experience has been that the forwards camera and the backup camera get most of the dirt, whereas the door mirror cameras get practically no dirt.
My solution? I have a microfiber cloth in the open storage area over the glove compartment. Whenever the cameras have a dirty picture, I will use the cloth to clean the cameras. I have done that about dozen times in 3500 km, and absolutely no damage to the lenses is visible. In theory, the scrubbing could damage the lens if it's dirty, but that probably occurs more slowly than in 3500 km. The microfiber cloth obviously gets dirty, but you can clean the backup camera using an area of the cloth that doesn't yet have dirt in it. One microfiber cloth will probably last for many years or more. When the entire cloth is dirty, you just replace it with a new one.
So, you need to clean the lenses more often than you fill up the gas tank. I don't see that as a problem, as it costs less than one minute of my time to clean the forwards and backup cameras.
Some car manufacturers have a camera that is held hidden when driving, and when the camera is active, electric motors move it out from the hidden position. This obviously eliminates the dirt problem, but also costs more, which is why all manufacturers don't do it.
juhist
  • 15,535
  • 13
  • 62
  • 104
I'm not sure how well it might work, but you could try NeverWet from Rust-Oleum. It is a super hydrophobic spray on solution which repels water very well. Could keep it clean by keeping it free of deposits. The only thing I am unsure of is how clear it goes on.
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
I also got fed up with this so moved my camers's front/back to the inside of the car now the wipers do the cleaning perfect picture 24/7.
To be honest i dont know why they are ever placed outside of the car common sense says there going to get filthy i bought 2 brckets of ebay stuck one behind the mirror on the windscreen (perfect) the other at the top of the rear window on a slight angle looking down a little yet again perfect.
The only turnkey solution I've seen. My friend from Germany sent me. The protective cover of the rear camera that he installed perfectly copes with the problem of a dirty camera. Here is a detailed description
Backup camera protection cover
user55713
one option is to have an auto electrician extend wiring and remount to a higher point.Some vehicles such as 4wds have masts at rear to mount camp lights & put camera there.You can affix a cowl plastic or metal top rear of your vehicle and achieve same result.Check sight picture before fixing in place permanently
mike
  • 647
Mount the camera inside the vehical at the back window ,if it has a rear wiper/sprayer ..problem solved Or alternatively reroute windshield washer fluid line to squirt the lens when the window sprayer is activated.
