I have Suzuki alto 2016 with manual gearbox. (Small car with 1.0 liter engine with 3 cylinders)
Sometimes, not always when I start moving in first gear at the moment when the engine speed equals the wheels speed (the moment when I need to release the clutch) I feel and hear a very strong shock in the whole car.
The strange thing that months can pass and it may not occur again. It mostly happens if I drive in a hilly area, but it doesn't end until I give the car a rest with a shutdown engine.
What do you think it could be?
I think if these were the motor mounts I would experience the problem regularly.
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
MyLight
  • 101
Motor mounts are a possibility but I would expect the problem to show up at other times as well. Basically anytime the engine is putting pressure on the mount and it's able to move.
Some other possibilities:
  1. Broken gear in the transmission.
  2. Bent or worn shift fork
  3. Failing CV shaft joint
  4. Broken suspension component
  5. Worn or damaged clutch
jwh20
  • 12,187
  • 17
  • 27
