This 2003 acrua mdx leaks coolant from the alternator and ac compressors bracket mounts and leaks between block down on the corner of the oil pan is there a freeze plug hole it could be leaking coolant from on the block or could it be the water pump sure could use some advice
Asked
Active
Viewed 95 times
