I have a VW Polo Classic, 1.6L.
Just recently it started to be slightly jerky when in idle and whilst driving. There is also a loss of power, a strong fuel smell, and sounding slightly like a VW Beetle.
I am thinking it is either:
  1. Spark plugs
  2. Fuel Filter
  3. Fuel Pump
Can anyone lend some advice on how to determine the issue?
dlu
  • 14,506
  • 52
  • 85
lordg
  • 173
5 Answers5
Other possible sources:
  • Vacuum Leak
  • Other Ignition item (Plug Wires, Distributer, etc.)
  • Really poor fuel
  • Air Filter Blocked
  • Exhaust Blockage
I would start with the spark plugs. Take them out and see if they can give any indication as to the true problem. See this answer for more info (While you have them out, replace them if you need to). Then start checking/replacing easy items like: Looking for disconnected hoses, checking the air filter, etc.
jzd
  • 3,615
  • 24
  • 35
Hi I had the same problem with my Polo 1.6 2008 model the HT leads come with a metal surround that arc's against the cylinder head remove the metal surround and it resolved me problem
Sam type R
MlAfter a lot of investigation, we found mine was caused by a wire that was coming away inside the distributor cap
Pete
Well, that sounds exactly like what my car had. Everything in your description matches what I was worrying about and at the shop they told me it was a faulty oxygen sensor. The repair will cost me $300 dollars.
dlu
  • 14,506
  • 52
  • 85
Kat
IAC, if it's fuel injected.
Mark Johnson
  • 3,931
  • 33
  • 56
