I am dealing with Cylinder Misfire p0300/P0302/P0304 codes on my Toyota MR2 Spyder and trying to get to the bottom of the issue.
Here is what I have tried so far:
  • Changed all 4 Spark plugs
  • Changed all 4 Ignition Coils
  • Checked wiring that goes into ignition coil
  • Added fuel system cleaner to the gas
So far no success.
Can someone point out what could be causing the problem, what additional tests I can perform to narrow down what part is likely causing the issue?
Asdfg
  • 143
Instead of replacing more parts, it's time to start diagnosing. Because you've already replaced some parts we will have to diagnose a little out of order. The next thing to do is a compression test.
If that passes the next step is to confirm replacement parts are good. First swap plugs 1 and 2 and swap plugs 3 and 4. If the codes don't change, the plugs are good.
Repeat this process with the coils and then injectors.
If all this checks out we can then check the signals to the coils and injectors and check to confirm the injectors are doing what's commanded. That should keep you busy for a little while.
Jupiter
  • 3,510
