12
I currently drive a Renault Clio III 1.5 dCi that just reached 200.000KM.
At my last checkup, the mechanic told me a timing belt change was necessary, along with a few other minor fixes.
I just bought a new car that will arrive in late August, so spending money on a new timing belt for a car that'll get scrapped in a few months seems silly.
My daily commute is 42km round-trip, 5-6 days a week. Would you recommend changing the belt anyway or can i keep driving until the new car arrives?
Thanks in advance
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
gorokizu
  • 223
The engine in your Renault is more than likely an interference engine. What this means is, if something were to happen to the belt, the engine will be history. This would leave you stranded, more than likely at the most inopportune time. Do you have a backup plan in case the car decides to have an issue because of the timing belt? If not, you should probably get the belt changed.
Did the mechanic state whether there was an actual issue with the belt or did they say this was a "regular maintenance item"? If there's a problem with the belt, you probably would want to change it out so the vehicle will last you until your new car arrives. If it's just a maintenance item, it will probably last you.
Is the car actually going to be scrapped? I mean, will you be sending it to the breakers (wrecking yard) and letting them have their way with it? If so, I doubt I'd change out the timing belt. If you are going to sell the car to someone, then I'd suggest to go ahead and change out the belt, because this would be a selling point which can garner you more money in a sale.
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
17
The change interval is either 5 years or 120.000km, whatever is reached first. Except for engine codes K9K766 and K9K770, where the interval is 5 years or 160.000km.
Now, the interval just "guarantees" that the timing belt will not fail within that time. It does not guarantee that the timing belt will fail if you miss the interval!
I would not change the timing belt. You'll be driving like 2.500km, which is about 2% of the change interval.
And, don't forget that there are other components which could fail. Spending maybe 400-500€ for the timing belt will make you feel foolish if the fuel pump fails a week later.
Luckily, you have a Diesel model, so you're safe from the usual trouble with the ignition coils. Instead, the injectors can fail. And if you have had occasional trouble starting the engine, expect the high-pressure pump to fail soon. If that happens, just spend your saved 500€ on an older used car which will last until late August.
Klaws
  • 286
