I agree with Paulster2's general advice.
It is not difficult to ask the cars computer what it is complaining about. Some cars have the ability to display the problem, aka the On Board Diagnostic II (OBD2) code, on the dashboard. Check the owners manual for this capability.
I like to use a phone based OBD2 scanner. Most modern cars are equipped with an OBD2 port.
https://www.plxdevices.com/obdii-compliant-vehicles-s/153.htm
Usually the port to connect to is below the dashboard on the drivers side.
Although I have a couple of these, I have good luck with this VeePeak scanner:
https://smile.amazon.com/gp/product/B073XKQQQW/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I use OBD Fusion on my iPhone. I find it easy to use, easy to read and clear codes and has gauges and more advanced diagnostics such as looking at the freeze frame data when the code was set.
https://www.obdsoftware.net/software/obdfusion
Some cars with set the Check Engine light on something simple, like low washer fluid.
I think this question and answer is helpful:
What possible causes for the "check engine" light can I check for myself?
