So I just purchased a 2000 Suzuki Katana 600. The bike cranks but doesn't want to start. I had the battery tested and it was good. I can get it started with some starter fluid. Then if I go ride it or it sits for any amount of time I have the same issue. It cranks over but it sounds like it's really struggling to do so then after continuously trying it stops cranking. So it sounds like a battery but was told it was good. Any help would be greatly appreciated.
Junder28
Always start with the basics. To run an gasoline internal combustion engine requires:
  1. Fuel
  2. Air
  3. Compression
  4. Ignition
First of all this bike has carburetors and these can be very sensitive to storage especially with ethanol-laced fuels. From your description that it starts on starter fluid indicate problems with fueling. You'll probably want to rebuild the carbs to resolve this issue. There are some in-fuel carb cleaning products but I've had little success with any of them. But they are relatively inexpensive and easy to use so it's probably worth a try. Also check that the choke or cold-start enriching circuit and its control is working properly.
Check your airbox and air cleaner to be sure nothing has built a nest in there and the filter is clean.
A compression test is simple enough to do and will give you an indication of the health of the piston rings and valves. These types of engines will run on 3 out of 4 cylinders but not well and can be difficult to start.
It sounds like your ignition, i.e. spark plugs and coils are working OK. So I'd leave those go for now.
jwh20
  • 12,187
  • 17
  • 27
