Why do my brakes squeak consistently when the brake pedal is halfway pressed but goes away when I press it down hard?
When I press my brakes I hear no squeaking for the first 10-20% of pressing down. Then I hear a loud high-pitched squeak when the pedal is about halfway down. If I keep the pedal halfway it will squeak the entire time. Then if I press down all the way the squeaking goes away. Basically its only squeaking for the middle portion of my braking action.
I got my brakes replaced about six months ago so I thought the "new brake" squeaking would have gone away by now.
Is this something to be concerned about? Should I take it in? Ford E250
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
carman
It's most likely due to one of a couple factors:
  • Your new brakes are budget materials and squeak
  • Whoever installed the brakes didn't add the brake squeak compound to take away these mini vibrations that cause squeaks
  • Your brake material is a bit glazed and squeaks because there are 2 slick surfaces gliding on each other
Whenever mine have squeaked, it's been 1 or a combination of these. There's no reason to be concerned at all - it's just annoying and even budget brakes will provide you with a decent service life. I've had squeaky brakes that lasted 50,000 miles with no indication of wearing out unfortunately.
Mr. Anderson
  • 297
