So basically I made the decision of investing in a 1987 MK3 Supra with an 350 small block engine swap. The current radiator is not cutting it and the vehicle overheats after 10 miles of driving when its less than 40 degrees Fahrenheit out. Any hotter than that and it's not even worth trying to drive it.
In a perfect world, I would actually have money for a radiator that would fit properly (a 3 core radiator from a 76 Nova). However I don't have money as I'm a teenager.
I have a wrecked 03 GMC Envoy with the Vortec 4200 engine. My plan is to pull the radiator from it and try to put it in the Supra. It'll obviously take some fabrication to make it to fit. However, the radiator will have to be on its side for it to fit. Below are the dimensions.
Nova
Core Dimensions: 26.25 x 17 x 1.25 in.
Core Material: Aluminum
Engine Oil Cooler: No
Inlet Size: 1.31 in.
Number of Rows: 1
Outlet Size: 1.56 in.
Envoy
17.94 x 27.06 x 1 in. core size
1.31 in. inlet size, 1.56 in. outlet size
2.25 x 27.38 in. top header, 2.25 x 27.17 in. bottom header
Top right inlet location and bottom left outlet location
The big question is: Will the radiator be able to operate properly when on its side?
Do you have any tips for putting it in?
One plan I have is to relocate the battery to the trunk(I haven't done it before, but I've heard of people doing it to make room).
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
Alec
  • 291
Yes, it will. However, your biggest concern is going to be getting enough air flowing over it. Do yourself a favour and go look at the engine bay of a 200x model Subary Impreza WRX. The intercooler is mounted flat on the top of the engine and the characteristic scoop forces air onto it to cool the intake air. The same type of thing might work for your radiator (which is basically an intercooler for water).
But if it were my car, I'd rather opt for two or more smaller radiators fitted behind the front bumper. Again, have a look at a regular turbo car's setup: the intercooler is placed below the radiator, behind the front bumper where lots and lots of high-speed air can flow over it. I'd keep the current radiator and have a second one mounted where the intercooler would go. You can call it a "two-stage cooling setup" and send me royalties or something ;)
Update: you may also want to double-check whether the current radiator is actually working properly. If there's a blockage somewhere, it may already explain a lot of your heat problems. It may end up saving you lots of money if it turns out you simply need to have your radiator flushed and filled with some new coolant/H20. But I wouldn't count on it. I just mention it for the sake of completeness.
Captain Kenpachi
  • 8,888
  • 26
  • 43
The bigger question here is, what are you actually gaining? The dimensions of the Envoy radiator is only marginally bigger than the current one. Your question, "Will it work?" is rather irrelevant. The pertinent question here should be, "Will it work better?" ... The answer to this is most probably No. You need to find another radiator which is the same dimensions as the current radiator (height and width) and have it thicker, like two or three cores thick. I know you said you are a student and cannot afford this, but obviously you are not driving it currently. If you cannot enjoy the car, what is the use. An easy way to save money on this is by going to a pull-a-part yard where you can measure out what might work, look for inlet/outlet locations, pull it yourself, and save a huge amount of money.
While Juann's suggestion of a secondary radiator is not without merit, it would be better to figure out what is wrong in the first place. His update starts with one solution, but there are other things you should be looking at.
First, are you sure your thermostat is up to snuff and working correctly? A closed thermostat would exhibit the same type of overheating. Can you put a lower temp thermostat in the car (and I know the answer to this is yes). Standard temp stat for the 350 is like 195F. Put a 180F one in there and see how that works you.
Another thing to look at is if there is a shroud around the fan? This is so commonly overlooked and is pretty easy to fix with some thin sheet metal or even an electric fan with its own shroud. The reason the shroud is important is, without it, the air mainly just whirls around the fan and has no direction. With it, the air is forcefully pulled through the radiator as it should be.
Speaking of the fan, is it working correctly? If a clutch fan, is the clutch portion locking up?
There are a lot of things you could be doing before you change out the radiator. To me it seems you'd be doing a lot of work for little gain.
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
