So my this question results form a conversation in chat of some different question. Where an experienced user shared some of his views which makes sense to me. So I want to go in more details.
Simply, I have a liquid wax. And I'm new to motorcycles and waxing.
So I waxed my bike only once, 1 month ago. When I applied it, it got dried with a white layer and then I buffed it and it became glossy/shiny.
I read at some sources that if wax is done properly it makes water beads/drops on the paint. Which I guess is one of the ways to find out if bike is waxed or not.
Also, the user shared few more important/useful things like:
You have a liquid wax:
  1. If it leaves no wax film at all, then it might be a bad product
  2. It doesn't contain 100% carnauba (so okay but not very good wax)
  3. If it leaves a long-lasting high-gloss film, then it is assumed a good product
So considering all things above, my confusion is I don't even know how to check if the wax I have applied is done properly or not?
I'm even more confused because my bike is new and it already has a glossy paint. So I can't figure out if the wax applied has a layer on it or not.
One more good reason to understand this is you'll know better when to wax your vehicle next time.
Given all that, what are some ways to find out the wax you have done on your motorcycle/car is done properly and the product definitely did left some layer/film over the motorcycle (e.g. wax layer in case of this wax product)?
Vikas
  • 301
  • 14
There's two ways:
By Touch: if you gently run a clean, dry finger tip along the paintwork before and after waxing you should feel a difference in friction - it should be appreciably reduced after the wax coat.
Hydrophobicity: you should see any water on the waxed surface forming either small "beads" that easily run off the car or potentially even "sheeting" where the water simply runs off the surface entirely. As this effect begins to lessen that's a sign that applying maintenance coat to the wax sometime soon is a good idea.
To address your specific points:
It should leave some wax/sealant layer behind, if it doesn't at all then it's not just a bad product, it's fundamentally failed at it's purpose.
It doesn't need to be 100% Carnauba - indeed many very good waxes aren't (there's some great synthetic polymer liquid waxes out there too!), and many cheap crap products use a low wax-content (but all of it being Carnauba) to claim that magical "100% Carnauba!!" on the packaging but are well.. crap.
Well.. not necessarily. That's certainly an indication of a good product. But there's more to it than that - how well it protects the paint from sunlight damage, how well it protects from water, ease of application, and so on. But if you're mainly looking for something to keep the vehicle looking decent and protect the paintwork better that's darn good place to start. It doesn't have to cost a great deal and you can usually keep on top of it with a wash and re-coat every 1-2 months (depending on environment).
motosubatsu
  • 10,632
  • 24
  • 42
