I need to have a special adapter that is formed by connecting two 3/8 " to 1/2 " adapters at 90 degrees angle. I want both ends of the adapter to be females only.
I have two of these:
And I want to attach them together like this without welding:
Is there any official adapter on the market to do it for me? Do I have to make one?
It is hard to find a L-shaped piece of metal and drill square holes on both ends of it.
@HandyHowie
As promised, I returned with pictures and more info. You asked about what I have done with my Allen key and two sockets.
These are my two 10 mm sockets and a 10 mm Allen key:
I connected the sockets to both ends of the Allen like this:
This is my torque wrench and a 1/2 " extension bar:
Now I connect the extension bar to the square drive of my torque wrench to form a long extension:
However, the above extension bar was just an example for demonstration purposes. I have another L-shaped extension bar that I want to connect to the torque wrench with the same method.
This is my L-shaped 1/2 " extension bar which I want to attach to my torque wrench:
Why I don't use this Allen Key method? Because the sockets need to be welded to Allen Key and I prefer to use welding as the last resort.
This way I can increase the torque and the following formula (which is offered by torque wrench manufacturers themselves) help me to know how much more torque I will apply to the fastener in each torque setting.
For instance, my torque wrench is 0.36 meter long. Without extension I need to apply 22.66 kg to its handle to produce 80 nm of torque. With my extension (0.42 meter + 0.10 meter the length of Allen Key = 0.52 meter), I need to apply only 9.27 kg to my torque wrench to produce the same 80 nm.
The main benefit of the extension is that it increases the maximum torque capacity of my torque wrench.
My torque wrench supports a range of between 15 and 80 nm. My lug nuts require 90 nm which exceeds my torque wrench capacity. With the extension, I need to set my torque wrench to 37 nm to produce 90 nm!
LFY MP7.3
  • 1,094
  • 14
  • 33
Using a 1/2 inch swivel adapter, you can plug the male end into a regular 16mm 1/2 socket. Plug it into the nut side as shown, leaving a second female 1/2 at the other side of the socket.
It fits really solid - even though it does not look like it in the picture, so should withstand reasonable workload as long as you are not giving it the beans.
Update: It looks like you are just trying to get extra reach? Take a look at serpentine belt tools. The smaller part:
Can be used to extend length of torque wrench:
The interesting thing about this setup is that you can add regular extensions to add depth if needed. This may also be an option.
Chris
  • 935
  • 19
Buy a 90˚ plumbing ell in metal like this:
(image from images.google.com)
Find a machine shop or a welder. Have your two adapters welded into the ell.
DavidRecallsMonica
  • 3,685
  • 19
  • 31
