Ok so my '97 Civic 150i is running a little to slow for my liking. I want it to be able to hang with a 2.0.
The first thing that comes to mind is swapping the motor out to make it the same as a VTEC under the hood.
What I want to know is, do I need to get the entire engine, motor. . .I'm really clueless?
Update; I've converted to a SOHC D16A right now and the mechanic (dad's cousin, so I know I can trust him) said I just need some suspension and brake upgrades/fixes and I can slap a SOHC vtec head on there :D
pythonian29033
  • 335
  • 19
Your most expensive problem is that a V-tec motor is designed to operate at higher RPM's than your motor can handle. This would mean that you'd have to get stronger pistons and connecting rods (or conrods as they're referred to). You'd also need to upgrade your valve springs to cope with the higher RPM. All in all, you're probably going to be spending about $2000 just on that. This by itself won't actually make your car perform any better, but without these upgrades, your engine won't last.
Another problem with your particular car is that you have a single camshaft doing the work, but a V-tec will need to have a double-camshaft setup, meaning you'll need to have a new cylinder head, including camshafts installed.
I'll stop now. The short answer is that if you want V-tec, it's going to be cheaper to just buy a secondhand V-tec.
Captain Kenpachi
  • 8,888
  • 26
  • 43
From what I understand, the accepted answer is not completely true. You do not need a dual cam setup to run vtec. I believe your civic has a stock d series engine which is a single cam most, likely a d16 (if you have a d15 it is more complicated).
The difference is with SOHC there is a common camshaft for both intake and exhaust valves. where as with DOHC there are separate cams.
VTEC is a variable valve timing system which is engaged at higher RMPs so you get better performance when you need it and don't burn extra gas and risk wear on your engine riding around at lower RPMs.
Civics are probably the most commonly modified hondas this question has been asked a million times, luckily that means there is a good amount of information on it. The first google search I found returned this. but there are many more some write ups even have detailed step by step picture tutorials.
http://honda-tech.com/honda-civic-del-sol-1992-2000-1/non-vtec-d16y7-convert-vtec-2531918/
At a minimum you will need a d series vtec head, a new ecu, and the wiring harness. (and probably need to replace a few more things like gaskets while doing the swap) also a new timing belt and water pump i believe.
While it is a good idea to upgrade many of the parts in your engine to help cope with the higher RPMs theoretically that isn't necessary, but you run a higher risk, especially if you have alot of miles on your car and like to engage vtec alot (kicks in around 5000rpms depending on the system)
Your mechanic friend is probably just saying cool things you could do. I believe the civics from that year have the same suspension and braking setups with or without vtec, although there are tons of aftermarket options if you are ambitious and have deep pockets. Similarly with the DOHC vtec, he was probably saying you should swap a B series motor into the car which is a very popular swap done to civics look (B16, b18, b20, etc).
John Dream
  • 602
  • 19
I also have a Ballade 150i Vti motor and also want to do something about the motor I did some research and found out that the quick way of gaining power is to add a turbo to the motor. I question was that will my motor be damaged easily. I discovered that I Make 67 kw on the wheel at the moment but if I put a T3/T4 turbo on the motor and Software, I will turn the boost max to 0.6 and the vti Motor will do about 176kw and 290NM on the wheel
The turbo and intercooler might cost you about 8K at the end and then just put everything together.
Jip I am Siuth African.. R 8k.. aprox. 600 usd... those parts i found in South Africa Johannesburg and Durban.... but i am sure its imports from Japan .... but you also need to add the fittings With bosch injectors Aem perfance cpu system, good intake + exhaust system etc... but after installing a turbo you need a dyno specialist to assist you to have a good condition motor which can easily reach 500hp and stil run healty..
But as they said the best way is to go D16A motor ...
