I have a new Yamaha motorbike. Seller told me not to ride speed more than 50 Kmph for first 1000KM but I rode it 60 for 10 - 15 minutes due to some reason. How does it affect to my Motorbike ?.
jzd
  • 3,615
  • 24
  • 35
Npn
  • 143
Breaking in the engine correctly will greatly affect the longevity and performance of the bike, plus you have warranty regards to worry about as well. I found this from a Yamaha forum and seems along the lines of what I understood to be right:
According to Yamaha, you are to keep the engine below 5900 rpm for the first 600 miles and vary the rpm. Do not do any steady high rpm rides like on the hwy. After that change the oil and filter and you are good to go. With todays technology in eng building, the engine is broken in after the first 100 miles. I kept my eng below 5900 for the first 100 miles and then varied it at short bursts up to 8000 for the next 200 miles. After that .....redline is the limit.
For best results, you can (at least here in the US) have the motorcycle dealer do the break-in for you. By doing so, you never have to worry about the boring part of owning your bike, that being the break-in period. As well, you know the warranty will be covered without issue.
I cannot tell you if your riding at 60kph for a period of time has done any damage. My gut check would tell me no, but you never know.
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
There's usually two methods people discuss. The 1st method is the one Paulster2 described, which is by the manufacturers suggestion in the manual. The 2nd is a more controversial method of running it hard.
Here's a snippet from [MotoMan][1]:
The Short Answer: Run it Hard !
Why ?? Nowadays, the piston ring seal is really what the break in process is all about. Contrary to popular belief, piston rings don't seal the combustion pressure by spring tension. Ring tension is necessary only to "scrape" the oil to prevent it from entering the combustion chamber.
If you think about it, the ring exerts maybe 5-10 lbs of spring tension against the cylinder wall ... How can such a small amount of spring tension seal against thousands of PSI (Pounds Per Square Inch) of combustion pressure ?? Of course it can't.
I'm not going to recommend which is right, but I'll provide a few more links of the 2nd method so you can read and make your own decision.
http://rideapart.com/2013/10/how-to-break-in-a-new-motorcycle-engine/ http://www.motorcycleextremist.com/Motorcycle-Engine-Break-in-the-Right-Way!.html
MD6380
  • 449
