I am rebuilding a previously seized engine and after sanding the sidewalls of the cylinder and piston with 1500 grit sandpaper (there was absolutely no other choice) The piston requires much force to move in the cylinder (I put the crankshaft on the piston and it did not move) I don't know if that is normal but I suspect it is not.
Is this normal and if not, how can I fix it?
Note 1: It is my first time rebuilding an en engine Note 2: It is impossible to get any spare parts.
Edit: I partially reassembled the engine and it is quite easy to spin it by spinning the flywheel.
Hristos
A friend (who is a car mechanic) came by and told me that everything is as it should be. I verified that with another friend so i am quite confident that it is ok. I will update once i start the engine.
Hristos
